Water/ink text
COW Forums : Boris FX Particle Illusion
shadu
Water/ink text
on Jun 19, 2005 at 10:45:56 am
I want to make a effect with a text.
The text is made on ink them flow down the page in drop or I was thinking that the words would blur and loose shape and start to gather together and then slide off the page.
Is their any way to make it in PI? If not any other application where i can do it?
Shadu
Elvis Deane
Re: Water/ink text
on Jun 19, 2005 at 6:45:45 pm
This can be done in pI. Make an emitter where the particles have no Velocity and a very long Life.
You should change Size Over Life so that the particles grow over time, and if you want it to drip and smear, give the particles a bit of Weight (you may want to use Weight Over Life so that they don't start dripping right away and Weight Variation so they don't all drip as much)
If you really want it to seem that the ink is soaking into the paper and blurring things, you can turn on Don't Erase in the Project Settings.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
