Cant open background
COW Forums : Boris FX Particle Illusion
Hexatron
on May 23, 2005 at 5:34:24 pm
In particleilluson, I can't open a background image, it says its an unsupported file format, how can I fix this?
Thankyou.
Alan Lorence
Re: Cant open background
on May 23, 2005 at 7:30:11 pm
What type of image are you trying to load? particleIllusion does not support every image format available.
Alan.
wondertouch
Hexatron
on May 24, 2005 at 2:33:58 pm
Aharon Rabinowitz
on May 24, 2005 at 2:39:14 pm
I think I understand. Are you trying to open it through the "file -> Open" command?
That's used to open pillusion files, not images.
To import an image do the following:
In the layer window (Top Left), double click on the gray box - it will open a dialog asking you to locate the BG image you want to import.
Check out this tutotorial to learn how to put particles over Background footage:
http://www.wondertouch.com/tutorials/aharon/basic/Tut_1.htm
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
Hexatron
on May 24, 2005 at 3:01:42 pm
I am doing that, Using the layers window, and it says 'Unsupported File Format' no matter which image I use
Alan Lorence
on May 24, 2005 at 3:10:58 pm
I don't think you have a complete installation. I recommend reinstalling.
Alan.
wondertouch
Hexatron
on May 25, 2005 at 4:32:56 pm
Thankyou, I reinstalled PI and it works :D
