Shadows
COW Forums : Particle Illusion
Steve D
Shadows
on May 17, 2005 at 5:30:13 am
Hi, I'm new to PI and love the software. Anyway, is there any way (hopefully easy)to add shadows to the emitters. Example: A shadow on the wall from a flickering candle, and faster movement shadows, striking a match etc. ?
Steve D
Elvis Deane
Re: Shadows
on May 17, 2005 at 6:25:11 am
The only way I can think of to create a shadow would be to duplicate your emitter, position it where you want the shadow to be, then use the Tint Color and Tint Strength graph to blacken the "shadow" emitter, and lower the Visibility. Then depending on the angle the shadow should be at, you could use the Angle property to tilt it the right way.
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
Steve D
Re: Shadows
on May 18, 2005 at 1:56:22 am
Thanks, I messed around a bit doing what you suggested, it got me real close to what I'm looking for, but I think it would probably take frame by frame painting to get believable shadows. I never realized how many variables there are in creating a shadow..thanks for the fast reply, I'll keep experimenting.
Steve D
Marco
Re: Shadows
on May 18, 2005 at 9:16:16 am
Hey Steve!
What i would recommend is to export it to After Effects and put a drop shadow on it and tweak from there. Works wonders..
Good luck!
Marco.
