last q
COW Forums : Particle Illusion
hobz
last q
by
on Apr 8, 2005 at 11:06:59 am
Am I able to get blue water, cosmos and lightsheet with SE(I bought for $99) because when I try to download files like someone told me(right clicking and selecting load library) nothing happens. all the files are empty(library backups, manuel and default IEL).So if I can download those effects please tell me what I'm doing wrong.thanks
Elvis Deane
Re: last q
on Apr 8, 2005 at 9:23:47 pm
What do you mean by empty? When you try to load an IEL, do you get an error, or does nothing at all appear in the library window in SE?
Elvis Deane!
The particleIllusion FAQ
particleIllusion Resources and tutorial CD
Astounding Adventures
hobz
Re: last q
by
on Apr 9, 2005 at 12:24:21 pm
I right click, click load library and then there's 3 lines. the first is library backups.If i press that its empty, the second is manual. If I choose that it says images. when I click images it says Guid 1,Guide2,Guide3,Guide4 and Guide5 and they are all empty.than back at the start the third line says default IEL and if I click that the box dissappears and I'm back on particle Illusion
Alan Lorence
Re: last q
on Apr 9, 2005 at 12:36:07 pm
Where did you put the files after you downloaded them? You need to use that "load library" dialog to browse to the correct folder, just like loading any other file.
Alan.
wondertouch
hobz
Re: last q
by
on Apr 9, 2005 at 1:05:12 pm
Wait, are you saying I have to download non-default libraries from this site?cos I didn't do that
Elvis Deane
Re: last q
on Apr 9, 2005 at 8:30:38 pm
At http://www.wondertouch.com/downloads.asp#IEL
Download the .zip files, and unzip them into your particleIllusion folder. Then when you right-click and choose Load Library, they will be available to load.
SE can load the libraries that were created before September 2002.
Elvis Deane!
hobz
Re: last q
by
on Apr 9, 2005 at 9:20:16 pm
thanx
