Rename text layer name based on the text content.
COW Forums : Adobe After Effects Expressions
Sumesh Surendran
on Feb 11, 2020 at 11:43:07 am
I want to rename text layer name based on the text content.
for example, I have text 1 layer which says Sunday, text 2 layer which says Monday, text 3 layer which says Tuesday......so on
how to rename?
text 1 layer to Sunday
text 2 layer to Monday
text 3 layer to Tuesday
like this I have 100 or more layers
is there way to do it fast with expression or scripts?
Andrei Popa
Re: Rename text layer name based on the text content.
on Feb 11, 2020 at 4:13:08 pm
Script:
crtComp = app.project.activeItem;
for (var i=1;i<=crtComp.numLayers;i++){
crtComp.layer(i).name = crtComp.layer(i).text.sourceText.value;
Andrei
My Envato portfolio.
Sumesh Surendran
on Feb 12, 2020 at 1:10:38 pm
Thank you Andrei Popa, This is exactly I want.
I think loop is breaking when there is another type of layer objects such as solid or shapes layer in between the text layers
example:
text layer 1 > renamed
text layer 2 > renamed
text layer 3 > renamed
solid layer
text layer 4 > did not renamed
text layer 5 > did not renamed
Andrei Popa
on Feb 12, 2020 at 1:17:04 pm
Try this:
currentLayer = crtComp.layer(i);
if(currentLayer typeof TextLayer){
currentLayer.name = currentLayer.text.sourceText.value;
Andrei
Sumesh Surendran
on Feb 12, 2020 at 1:30:06 pm
unable to execute script at line 5. expected: )
Andrei Popa
on Feb 12, 2020 at 1:33:39 pm
Sorry. I corrected this but then pasted the code from the clipboard. That one was not corrected 😃
if(currentLayer instanceof TextLayer){
Andrei
Sumesh Surendran
on Feb 12, 2020 at 1:57:53 pm
Now it works perfectly, Thank you very much Andrei :-)
