add expression to single keyframe
COW Forums : Adobe After Effects Expressions
Nelson Alves
on Jan 29, 2018 at 3:26:32 am
Hi there,
I'm creating a camera move into a world map and need to zoom into a specific position on that map.
I want to set it up that so the client can simply move a null (xyz) or object on the map that sets the location where the camera move ends.
So essentially I was going to create a separate null that the client can move on the map and that will indicate the final location but if I pickwhip the position to the null it will affect both (start and end) keyframes. Is there any way of writing an expression for the second keyframe only without affecting the opening keyframe?
I hope this makes sense.
Thanks.
Dan Ebberts
Re: add expression to single keyframe
on Jan 29, 2018 at 7:20:23 am
It depends on what you're animating, but something like this might work:
p = thisComp.layer("target").position;
v1 = key(1).value;
v2 = key(2).value;
linear(value[2],v1[2],v2[2],v1,p);
Dan
Nelson Alves
on Feb 5, 2018 at 4:53:14 am
Thanks for your answer Dan. Greatly appreciated.
Nelson
