Turn on opacity of a layer using a mark
COW Forums : Adobe After Effects Expressions
Marcelo Cabral
on Oct 2, 2017 at 12:55:22 pm
Hi there. I need a little help on this.
I have two compositions nested. First one (CUBE) has a simple solid and the main one (MASTER) has an adjustment layer with a mark. I need to turn on the opacity of the solid layer with this mark.
In other words, the opacity of the solid will be in 0 and when the indicator pass over the mark named "01" it has to turn on the opacity to 100.
Is it possible?. Thank you in advance.
Dan Ebberts
Re: Turn on opacity of a layer using a mark
on Oct 2, 2017 at 1:28:25 pm
This should work:
C = comp("MASTER");
L = C.layer("Adjustment Layer 1");
t = L.marker.key("01").time - C.layer(thisComp.name).startTime;
if (time < t) 0 else 100
Dan
Marcelo Cabral
on Oct 2, 2017 at 1:44:48 pm
Works perfectly, Thank you, Dan!!!
