Change position property of an object with a check box
COW Forums : Adobe After Effects Expressions
Marcelo Cabral
on Sep 28, 2017 at 9:27:09 pm
Hi. I wondering if it's possible to change the position of a 2D object using a checkbox expression effect.
If the checkbox is on the object is in the A position and when the box is unchecked the object change the position to position B.
Thank you.
Marcelo
Leopoldo Perizzolo
Re: Change position property of an object with a check box
on Sep 28, 2017 at 10:26:06 pm
Something like this should do; apply a Checkbox control on the layer and paste this on the position property:
posA = [200, 400]; // "checkbox enabled" position
posB = [600, 100]; // "checkbox disabled" position
try{
if(effect("ADBE Checkbox Control-0001")(1) == true) posA;
else posB;
catch(e){
value;
Leopy
Leopoldo Perizzolo
on Sep 29, 2017 at 10:40:06 am
Sorry, I meant:
try{
if(effect("ADBE Checkbox Control")("Casella") == true) posA;
else posB;
catch(e){
value;
Leopy
Leopoldo Perizzolo
on Sep 29, 2017 at 10:42:22 am
Testing.... 😅
try{
if(effect("ADBE Checkbox Control")(1) == true) posA;
else posB;
catch(e){
value;
I didn't make it universal.
Leopy
Marcelo Cabral
on Sep 29, 2017 at 1:11:24 pm
Hi Leopy
Thank you for your response and support ☺ I'm starting my day right now. I will give it a try, sure it will work fine.
Cheers
Marcelo
Marcelo Cabral
on Sep 29, 2017 at 1:19:37 pm
Hi Leopy
It doesn´t work. Maybe I am doing something wrong. I have attached an image to show you how I am using it in AE.
Cheers.
Dan Ebberts
on Sep 29, 2017 at 5:16:27 pm
Try it this way:
if(thisComp.layer("CONTROL").effect("POSITION")(1).value)
posA
else
posB;
Dan
