Year countdown timer expression problem
COW Forums : Adobe After Effects Expressions
Graham Harris
on Sep 16, 2017 at 10:58:21 am
I'm trying to create a timer that countdown from 1 year and displays in years, months, days, minutes and seconds. I found a suitable expression on an adobe forum but when run it populates the day, minute and second fields with NA. The expression is below. Any help in getting this to work would be gratefully received. As you can guess I know just enough about expressions to make myself look stupid.
totalTimeInSeconds = 31400000;
secondsPerMinute = 60;
secondsPerHour = 60 * 60;
secondsPerDay = 60 * 60 * 24;
secondsPerMonth = 60 * 60 * 24 * 30;
secondsPerYear = 60 * 60 * 24 * 30 * 12;
secondsRemaining = totalTimeInSeconds;
years = Math.floor(secondsRemaining / secondsPerYear);
secondsRemaining = secondsRemaining % years;
months = Math.floor(secondsRemaining / secondsPerMonth);
secondsRemaining = secondsRemaining % months;
days = Math.floor(secondsRemaining / secondsPerDay);
secondsRemaining = secondsRemaining % days;
hours = Math.floor(secondsRemaining / secondsPerHour);
secondsRemaining = secondsRemaining % hours;
minutes = Math.floor(secondsRemaining / secondsPerMinute);
secondsRemaining = secondsRemaining % minutes;
seconds = secondsRemaining;
txt = "";
txt += yearleadingZeros(years);
txt += leadingZeros(months);
txt += leadingZeros(days);
txt += leadingZeros(hours);
txt += leadingZeros(minutes);
txt += leadingZeros(seconds);
txt;
function yearleadingZeros(i){
x = "0" + Math.floor(i);
return x;
function leadingZeros(i){
x = ":" + x.substr(x.length-2, 2);
return x;
Andrei Popa
Re: Year countdown timer expression problem
on Sep 18, 2017 at 6:26:50 am
The aN is from the NaN error, which means Not a Number. That is because by the time you get to the days you already are trying to do 0%0, which does not have a result. The problem is that you use the number of years, months, etc in your % operation. This should work.totalTimeInSeconds = 31400000;
secondsRemaining = secondsRemaining % secondsPerYear;
secondsRemaining = secondsRemaining % secondsPerMonth ;
secondsRemaining = secondsRemaining % secondsPerDay ;
secondsRemaining = secondsRemaining % secondsPerHour;
secondsRemaining = secondsRemaining % secondsPerMinute ;
txt = "";
txt;
return x;
return x;
Andrei
Graham Harris
on Sep 19, 2017 at 6:22:44 pm
Thanks Andrei, I really appreciate you taking the time to look at this. It now displays numbers instead of NA! Unfortunately it doesn't count down when I run it. Would you have any idea why that is?
Graham Harris
on Sep 19, 2017 at 6:52:28 pm
Sorry! It's been a long day, I realised I had hard coded the time to a single variable so the expression is unable to count up or down. I altered the expression as below and it appears to do what I want, at least I can render it out and then reverse it in premiere to do what I want. Thanks again for your help Andrei.
countspeed = 100;
clockStart = 31102010;
function times(n){
if (n &lt; 10) return "0" + n else return "" + n
clockTime = clockStart +countspeed*(time - inPoint);
if (clockTime &lt; 0){
minus = "-";
clockTime = -clockTime;
}else{
minus = "";
totalTimeInSeconds=clockTime
txt = "";
txt;
return x;
return x;
