real value to change comp duration
COW Forums : Adobe After Effects Expressions
Rainier Raydán
on Aug 30, 2017 at 7:56:17 pm
Hi guys! I'm working in a script to change the duration (and other things) of the or selected comps. The problem is that the value that I get when I use alert(selectedComps.duration) is very strange for me. In the timeline we can see fps and timecode (0:00:00:00) but the value I get from that alert is "x.yyy", I can see that x is the amount in seconds of the composition but after "." they are decimals that I cant figure it out how it works. I soupose is the fps divided by a number I dont know...
I'm thinking in a text box to get the first number (seconds), do praseFloat() and get a real number. Also other box to get the frames and apply a math function to it. Do you guys knows any math function I can use?
Andrei Popa
Re: real value to change comp duration
on Aug 31, 2017 at 8:10:10 am
var compLength = selectedComps.duration;
var minutes = Math.floor(compLength / 60);
var seconds = Math.floor(compLength % 60);
var frames = Math.round((compLength - Math.floor(compLength))/selectedComps.frameDuration);
alert (minutes +":"+ seconds +":"+ frames);
I don't know if it works with multiple selected comps.
Andrei
Rainier Raydán
on Aug 31, 2017 at 1:36:14 pm
Nice! Thanks Andrei!
But I need to change the duration of the comp with this values
I want to set the minutes, the seconds and the number of frames with this UI but I dont know how!
Andrei Popa
on Aug 31, 2017 at 6:20:10 pm
You just reverse the process. Lets say the variables for the texts of this GUI are sec,min,fps,frames.
min*60 + sec + frames/fps
Andrei
Rainier Raydán
on Sep 1, 2017 at 8:29:28 pm
Ok I have this
var compLength = app.project.activeItem.duration;
var minutes =2
var seconds = 15
var frames = 20;
minSec = (minutes*60)+seconds;
realFrames = frames /app.project.activeItem.frameDuration;
finalDuration = parseFloat (minSec +"."+realFrames);
app.project.activeItem.duration = finalDuration;
But the comp duration still wrong. It has to be 02:15:20 (it's a 25 frames comp) but the script result is 02:15:13...
Andrei Popa
on Sep 2, 2017 at 6:09:51 am
That is because you used frameDuration instead of fps. Fps is 1/frameDuration, which makes your realFrames value frames*app.project.activeItem.frameDuration. The script would be like this
var minutes =2
var seconds = 15
var frames = 20;
realFrames = frames *app.project.activeItem.frameDuration;
finalDuration = minSec +realFrames;
Andrei
Rainier Raydán
on Sep 3, 2017 at 12:44:32 pm
Wow! That help! It worked just fine but when the comp is 23.976 fps it doesnt work... when the minutes value its greater thant 0 the results in frame and in seconds doesnt match... minutes = 1, secondes = 10 and frames = 5 and the result is 0:01:10:03...
Andrei Popa
on Sep 4, 2017 at 6:51:49 am
It seems that there is a problem with this framerate. Even if you put an integer as the duration, you get some frames.
Andrei
