Attach anchorpoint to the center of the layer
COW Forums : Adobe After Effects Expressions
Rainier Raydán
on Aug 16, 2017 at 3:02:45 pm
Hi! I have this shapeLayer who grows when a text is fill. The position of this layer is already attach to the center of the composition with thicComp.width/2
now, I need the anchorpoint to be in the center of the width of the layer but I cant figurate out how to do it...
this is a image of what Im trying to do
this is the image with the wrong anchorpoint when I fill both text
thanks guys!
Andrei Popa
Re: Attach anchorpoint to the center of the layer
on Aug 16, 2017 at 3:14:14 pm
The solution for making the anchor point always in the middle is
tempx = thisLayer.sourceRectAtTime(time,false).width/2 + thisLayer.sourceRectAtTime(time,false).left;
tempy = thisLayer.sourceRectAtTime(time,false).height/2 + thisLayer.sourceRectAtTime(time,false).top;
[tempx,tempy]
but you may run into some problems with the position by changing it with expressions. You may have to also alter the position expression.
Andrei
Rainier Raydán
on Aug 16, 2017 at 3:28:12 pm
WOW! thank you so much! Works like a charm 😊
Rainier Raydán
on Aug 24, 2017 at 1:58:55 pm
Sorry, do you have any idea on how to set the anchor point to upper right or left, center right or left and so?
Andrei Popa
on Aug 24, 2017 at 3:30:37 pm
Here is a "crash course" for the sourceRectAtTime(time, false) function. In the picture you see the values it has for top, left, height and width. What you must remember is that while the anchor point is below the top of the layer the "top" value is negative. Also, if the anchor point is to the right of the left extremity, the left value is negative. You always have negative values for this variables while inside the rectangle. The x position is where the anchor is at its [0,0](where the anchor point is before you do any transformation to it). So for you to move it around, you only have to do some basic geometry. Here is a pic and also the values of x,y for all the positions you needed them. You can combine them as you like for different results.
//x values
//left
x = thisLayer.sourceRectAtTime(time,false).left;
//right
x = thisLayer.sourceRectAtTime(time,false).width + thisLayer.sourceRectAtTime(time,false).left;
//mid
//y values
//top
y = thisLayer.sourceRectAtTime(time,false).top;
//mid
//bottom
y = thisLayer.sourceRectAtTime(time,false).height + thisLayer.sourceRectAtTime(time,false).top;
Andrei
Rainier Raydán
on Aug 24, 2017 at 3:49:54 pm
Atul Rajput
on Aug 9, 2018 at 6:49:57 am
Hello Andrei Popa,
Is there any way by which I can set the anchor position centre without changing the layer position in UI. and then make the anchor point back there, where it was.
Andrei Popa
on Aug 9, 2018 at 7:17:01 am
I don't think you can. But you have some sort of workaround. Make a null, put it in the middle of your layer, parent your layer to it and apply the transformations you need to the null.
Andrei
My Envato portfolio.
