[ADVICE] After Effects Time Expression changes the Rotation position of object!
COW Forums : Adobe After Effects Expressions
Sonia Li
on Aug 11, 2017 at 7:12:29 pm
I'm working in After Effects and come across something that I've been Googling to no avail. Should be fairly simple but having trouble figuring it out.
Basically, when I use the time expression (time*500) in Rotation, the expression sets my object Rotation position to 0. (original position of object is not 0) This changes the composition of my object. How do I use the time expression without having it change my composition??
Thanks so much in advance!!
Andrei Popa
Re: [ADVICE] After Effects Time Expression changes the Rotation position of object!
on Aug 11, 2017 at 7:52:26 pm
Try this
time*500+value
Andrei
Sonia Li
on Aug 11, 2017 at 8:08:18 pm
Thanks so much Andrei! Works like a charm ☺
Andrei Popa
on Aug 12, 2017 at 10:48:15 am
You are welcome. Glad i could help.
Andrei
