Auto-sized box under your text. How to control the width and height of that box?
COW Forums : Adobe After Effects Expressions
Joel Arvidsson
on Aug 6, 2017 at 3:47:47 pm
Im doing a motion graphic template in after effect to use in premiere. The goal is to make text with an autoscaling box under it.
While I found a couple of tutorials on how do this but I wish to be able to control the height and width of the backround box separately. I have tried the offset path inside of the shapelier (the background box) and it would worked perfect if only you could scale x and y separately.
But all my attempts have failed.
I was hoping the offset path in the shape layer would do the trick but it only scales uniformly on x and y.
joelarvidsson@gmail.com
Dan Ebberts
Re: Auto-sized box under your text. How to control the width and height of that box?
on Aug 6, 2017 at 6:43:57 pm
If you're using a rectangle shape, you adjust x and y of the path Size parameter separately.
Dan
Joel Arvidsson
on Aug 6, 2017 at 9:05:09 pm
I tried that but it seams to offset the bg rectangle when typing. This is due to the expressions that scales the bg rectangle based on the characters.
