changing text color within a "tag"
COW Forums : Adobe After Effects Expressions
nicholas kiray
on Jul 31, 2017 at 8:41:15 pm
hi!
I want to create an expression that changes color between two tags. For example, in this sentence:
Hello, my name is Nick.
it would be typed like this in the text layer
Hello, my name is [Nick].
I already figured out how to remove the brackets, what I'm struggling with now is how to change the color. I tried making an expression in the fill color but nothing happens, even when I disable the expression that removes the brackets from the string.
(note: "<" is showing up as "<" for some reason in the code")
thank you!
Nick
<code>
highlight = comp("COLOR CONTROL").layer("TYPE ACCENT COLOR HERE").text.animator("Animator 1").property.fillColor;
normal = comp("COLOR CONTROL").layer("TYPE TEXT COLOR HERE").text.animator("Animator 1").property.fillColor;
output = normal;
for (i = 0; i &lt; text.sourceText.length; i++){
if (text.sourceText[i] == "["){
output = highlight;
if (text.sourceText[i] == "]"){
output = normal;
output
</code>
Dan Ebberts
Re: changing text color within a "tag"
on Jul 31, 2017 at 10:40:46 pm
I'm not sure this will help, but it might give you some ideas.
If you add a Fill RBG animator, and an Expression selector, then apply this expression to the Amount property:
txt = text.sourceText;
val = 0;
b1 = txt.indexOf("[");
b2 = txt.indexOf("]");
if (b1 > -1 && b2 > -1 && b2 > b1){
if ((textIndex-1) > b1 && (textIndex-1) < b2) val = 100;
val
It should apply the fill color to anything between "[" and "]". The expression would need to be modified if you have multiple lines in the text. It would also need to be modified if you have more than one word that needs to be tagged.
BTW--the way to avoid having your < characters mangled is to post direct, without previewing.
Dan
nicholas kiray
on Aug 1, 2017 at 3:22:21 pm
it works!!!!! thank you so much!!!!!
the only issue I have now is when I remove the "[" and "]" brackets from the string using the below code, it doesn't read as characters in the fill. Is there a way I can read the "fill" expression before the source text's expression?
str = text.sourceText;
res1 = str.replace("[", "");
res2 = res1.replace("]", "");
[res2]
Dan Ebberts
on Aug 1, 2017 at 4:10:39 pm
I think I'd try it this way--change your Source Text expression so that it replaces the brackets with zero-width space characters:
zws = "\u200b";
res1 = str.replace("[", zws);
res2 = res1.replace("]", zws);
Then change your Expression Selector expression to look for those:
zws = "\u200b";
val = 0;
b1 = txt.indexOf(zws);
b2 = txt.lastIndexOf(zws);
val
Dan
nicholas kiray
on Aug 1, 2017 at 4:17:04 pm
I had a similar idea! I did it a little differently though; basically added an expression selector for "opacity" and "tracking" and when the if statement found a "[" or "]", it would change the opacity to 0 and change the tracking to -45. Technically the brackets are still there but they are invisible ☺
thank you so much for your help dan!
val = 0;
if (textIndex== b1 || textIndex == b2) val = textIndex;
val
nicholas kiray
on Aug 1, 2017 at 9:23:54 pm
*edit* your method of using the zero width space worked much better than my kerning attempt. nice job!
