Importing Problem with expressions.
COW Forums : Adobe After Effects Expressions
George Felix
on Jul 5, 2017 at 5:04:34 pm
I got a real strange problem.
Operating System Windows 10
I am able to import text files that have a .prn ending but I am unable to import the same text file when it has an .txt ending
Any suggestions? Is this a bug for Windows 10
The source.txt were created with notepad
DOES NOT WORK
try{
$.evalFile(C:\Users\George\Desktop\<b>source.txt</b>);
teamHome;
}catch(err){
"MISSING";
WORKS
try{
$.evalFile(C:\Users\George\Desktop\<b>Data.prn</b>);
teamHome;
}catch(err){
"MISSING";
Dan Ebberts
Re: Importing Problem with expressions.
on Jul 5, 2017 at 7:11:54 pm
What's in the text file?
Dan
George Felix
on Jul 5, 2017 at 7:39:09 pm
Variable to be imported for soccer graphics. Below is the variables which their are about 125 different ones.
The same file gets imported if the extension is a ".prn" instead of a ".txt"
var TeamH = ["test1","test1","test1"];
var GoalieH = ["test1","test1","test1"];
var RbackH = ["test1","test1","test1"];
var CRbackH = ["test1","test1","test1"];
var CLbackH = ["test1","test1","test1"];
var LbackH = ["test1","test1","test1"];
George Felix
on Jul 5, 2017 at 7:53:11 pm
An other question, would it be possible to link the data file on a web server and have a path like
http://www.inkarpathos.gr/program/user1/data.txt
in the script?
Dan Ebberts
on Jul 5, 2017 at 8:06:51 pm
I believe you could do that with a script, but not an expression.
Dan
Dan Ebberts
on Jul 5, 2017 at 8:05:54 pm
So you're saying if you take the exact same file that works as a .prn and change its extentsion to .txt (and make the same change in the expression's path), it doesn't work? That surprises me.
Dan
George Felix
on Jul 5, 2017 at 8:25:26 pm
Yes, the same file, just change the extension from ".prn" to ".txt" but it does not work.
