Getting an error with this AE script, importing MIDI data to AE as a comp
COW Forums : Adobe After Effects Expressions
Shahid Raza
on Jul 3, 2017 at 10:35:51 pm
Ok so the scripts I'm using here are not mine and I want to make them work.
I've exported MIDI data to a .jsx file using the following program:
http://www.mediafire.com/file/c4c7fn4cxz7s4is/midi2jsx.jar
Using this Terminal command:
java -jar midi2jsx.jar [file_name].mid
This generated an output in Terminal like this:
File: [file_name].mid
Length: 595201 ticks
Duration: 491786485 microseconds
DivisionType: PPQ
Resolution: 960 ticks per beat
Track 0:
tick 0: Time Signature: 3/4, MIDI clocks per metronome tick: 24, 1/32 per 24 MIDI clocks: 8
tick 0: Key Signature: C major
tick 0: Set Tempo: 80.0 bpm
tick 0: Sequence/Track Name: Interstellar - First Step [Kyle Landry Cover]
tick 128880: Set Tempo: 77.0 bpm
tick 129600: Set Tempo: 77.0 bpm
tick 129600: Set Tempo: 80.0 bpm
tick 129600: Time Signature: 4/4, MIDI clocks per metronome tick: 24, 1/32 per 24 MIDI clocks: 8
tick 129840: Set Tempo: 83.0 bpm
tick 130080: Set Tempo: 85.0 bpm
tick 130560: Set Tempo: 82.0 bpm
tick 130800: Set Tempo: 78.0 bpm
tick 131280: Set Tempo: 75.0 bpm
tick 131520: Set Tempo: 72.0 bpm
tick 132000: Set Tempo: 70.0 bpm
tick 132240: Set Tempo: 67.0 bpm
tick 132720: Set Tempo: 63.0 bpm
tick 133200: Set Tempo: 54.0 bpm
tick 133440: Set Tempo: 54.0 bpm
tick 133440: Set Tempo: 45.0 bpm
tick 133440: Time Signature: 3/4, MIDI clocks per metronome tick: 24, 1/32 per 24 MIDI clocks: 8
tick 133920: Set Tempo: 55.0 bpm
tick 134160: Set Tempo: 59.0 bpm
tick 134400: Set Tempo: 63.0 bpm
tick 134640: Set Tempo: 65.0 bpm
tick 134880: Set Tempo: 68.0 bpm
And created a MIDIdata.jsx file which I then opened and pasted it's content into the code below where it says to paste mididata.
After going to File > Scripts > Run Script File and ran the MIDI_to_AE.jsx file (which has the code below) and it gives me this error.
Unable to execute script at line 58. After Effects error: Unable to call "addSolid" because of parameter 3. Infinity is not an integer.
I can get this to work for a small MIDI piece with 2 channels but for an 8 minute long piece, it throws an error.
Here's the MIDI_to_AE.jsx file's code (with the extracted MIDI .jsx data too).
Basically I'm trying to create a piano roll with falling notes from top to bottom by reading the MIDI data.
If there's a better solution, or any advice on code changes to the script below would be much appreciated.
/********************** PASTE MIDIDATA BELOW ***************************/
var bpm=20.0
var duration=491.78648499999997
var channels=[0,1,2]
var Times = new Array();
var OnOff = new Array();
var Velocities = new Array();
var Tones = new Array();
// Channel 0
Times[0]=[39.0,39.0,53.2375,53.2375,54.0,54.0,71.09688,71.09688,72.0,72.0,74.9875,74.9875,75.0,75.0,77.9875,77.9875,78.0,78.0,80.9875,80.9875,81.0,81.0,83.9875,83.9875,84.0,84.0,86.9875,86.9875,87.0,87.0,89.9875,89.9875,90.0,90.0,98.9875,98.9875,99.0,99.0,107.54375,107.54375,111.0,116.69688,120.0,125.69688,129.0,134.69687,138.0,143.69687,147.0,152.69687,156.0,161.69687,165.0,170.69687,174.0,179.69687,183.0,188.69687,192.0,197.69687,201.0,206.69687,210.0,215.69687,219.0,224.69687,228.0,233.69687,552.0,560.54376,565.5,578.3219,583.5,596.3219];
OnOff[0]=[1,1,0,0,1,1,0,0,1,1,0,0,1,1,0,0,1,1,0,0,1,1,0,0,1,1,0,0,1,1,0,0,1,1,0,0,1,1,0,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0];
Velocities[0]=[64,64,0,0,82,82,0,0,52,52,0,0,58,58,0,0,69,69,0,0,60,60,0,0,54,54,0,0,60,60,0,0,69,69,0,0,60,60,0,0,63,0,64,0,67,0,65,0,73,0,70,0,78,0,74,0,76,0,64,0,80,0,86,0,91,0,97,0,102,0,114,0,120,0];
Tones[0]=[57,69,57,69,59,71,59,71,57,69,57,69,59,71,59,71,60,72,60,72,59,71,59,71,57,69,57,69,59,71,59,71,60,72,60,72,59,71,59,71,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,76,88,88,88,88,88,88];
// Channel 1
Times[1]=[3.0,4.41875,4.5,5.91875,6.0,7.41875,7.5,8.91875,9.0,10.41875,10.5,11.91875,12.0,13.41875,13.5,14.91875,15.0,16.41875,16.5,17.91875,18.0,19.41875,19.5,20.91875,21.0,22.41875,22.5,23.91875,24.0,25.41875,25.5,26.91875,27.0,28.41875,28.5,29.91875,30.0,31.41875,31.5,32.91875,33.0,34.41875,34.5,35.91875,36.0,37.41875,37.5,38.91875,39.0,40.41875,40.5,41.91875,42.0,43.41875,43.5,44.91875,45.0,46.41875,46.5,47.91875,48.0,49.41875,49.5,50.91875,51.0,52.41875,52.5,53.91875,54.0,55.41875,55.5,56.91875,57.0,58.41875,58.5,59.91875,60.0,61.41875,61.5,62.91875,63.0,64.41875,64.5,65.91875,66.0,67.41875,67.5,68.91875,69.0,70.41875,70.5,71.91875,72.0,73.41875,73.5,74.91875,75.0,76.41875,76.5,77.91875,78.0,79.41875,79.5,80.91875,81.0,82.41875,82.5,83.91875,84.0,85.41875,85.5,86.91875,87.0,88.41875,88.5,89.91875,90.0,91.41875,91.5,92.91875,93.0,94.41875,94.5,95.91875,96.0,97.41875,97.5,98.91875,99.0,100.41875,100.5,101.91875,102.0,103.41875,103.5,104.91875,105.0,106.41875,106.5,107.91875,108.0,108.0,109.41875,109.5,110.91875,111.0,112.41875,112.5,113.91875,114.0,115.41875,115.5,116.54375,116.91875,117.0,117.0,118.41875,118.5,119.91875,120.0,121.41875,121.5,122.91875,123.0,124.41875,124.5,125.54375,125.91875,126.0,126.0,127.41875,127.5,128.91875,129.0,130.41875,130.5,131.91875,132.0,133.41875,133.5,134.54375,134.91875,135.0,135.0,136.41875,136.5,137.91875,138.0,139.41875,139.5,140.91875,141.0,142.41875,142.5,143.54375,143.91875,144.0,144.0,145.41875,145.5,146.91875,147.0,148.41875,148.5,149.91875,150.0,151.41875,151.5,152.54375,152.91875,153.0,153.0,154.41875,154.5,155.91875,156.0,157.41875,157.5,158.91875,159.0,160.41875,160.5,161.54375,161.91875,162.0,162.0,163.41875,163.5,164.91875,165.0,166.41875,166.5,167.91875,168.0,169.41875,169.5,170.54375,170.91875,171.0,171.0,172.41875,172.5,173.91875,174.0,175.41875,175.5,176.69687,176.91875,177.0,177.0,178.41875,178.5,179.84688,179.91875,180.0,180.0,181.41875,181.5,182.84688,182.91875,183.0,183.0,184.41875,184.5,185.84688,185.91875,186.0,186.0,187.41875,187.5,188.84688,188.91875,189.0,189.0,190.41875,190.5,191.84688,191.91875,192.0,192.0,193.41875,193.5,194.84688,194.91875,195.0,195.0,196.41875,196.5,197.84688,197.91875,198.0,198.0,199.41875,199.5,200.84688,200.91875,201.0,201.0,202.41875,202.5,203.84688,203.91875,204.0,204.0,205.41875,205.5,206.84688,206.91875,207.0,207.0,208.41875,208.5,209.84688,209.91875,210.0,210.0,211.41875,211.5,212.84688,212.91875,213.0,213.0,214.41875,214.5,215.84688,215.91875,216.0,216.0,217.41875,217.5,218.84688,218.91875,219.0,219.0,220.41875,220.5,221.84688,221.91875,222.0,222.0,223.41875,223.5,224.84688,224.91875,225.0,225.0,226.41875,226.5,227.84688,227.91875,228.0,228.0,229.41875,229.5,230.84688,230.91875,231.0,231.0,232.41875,232.5,233.84688,233.91875,234.0,234.0,235.41875,235.5,236.84688,236.91875,237.0,237.0,238.41875,238.5,239.84688,239.91875,240.0,240.0,241.41875,241.5,242.84688,242.91875,243.0,243.0,243.0,243.0,245.84688,245.84688,245.84688,245.84688,246.0,246.0,246.0,246.0,248.84688,248.84688,248.84688,248.84688,249.0,249.0,249.0,249.0,251.84688,251.84688,251.84688,251.84688,252.0,252.4,252.79688,253.19687,254.9875,254.9875,254.9875,254.9875,255.0,255.0,255.0,257.84686,257.84686,257.84686,258.0,258.0,258.0,258.0,260.84686,260.84686,260.84686,260.84686,261.0,261.4,261.79688,262.19687,263.9875,263.9875,263.9875,263.9875,264.0,264.0,264.0,266.84686,266.84686,266.84686,267.0,267.0,267.0,267.0,269.84686,269.84686,269.84686,269.84686,270.0,270.4,270.79688,271.19687,272.9875,272.9875,272.9875,272.9875,273.0,273.0,273.0,275.84686,275.84686,275.84686,276.0,276.0,276.0,278.84686,278.84686,278.84686,279.0,279.4,279.79688,280.19687,281.9875,281.9875,281.9875,281.9875,282.0,282.0,282.0,284.84686,284.84686,284.84686,285.0,285.0,285.0,287.84686,287.84686,287.84686,288.0,288.0,288.0,288.0,290.84686,290.84686,290.84686,290.84686,291.0,291.0,291.0,293.84686,293.84686,293.84686,294.0,294.0,294.0,294.0,296.84686,296.84686,296.84686,296.84686,297.0,297.0,297.0,297.0,299.84686,299.84686,299.84686,299.84686,300.0,300.0,300.0,302.84686,302.84686,302.84686,303.0,303.0,303.0,303.0,305.84686,305.84686,305.84686,305.84686,306.0,306.0,306.0,306.0,308.84686,308.84686,308.84686,308.84686,309.0,309.0,309.0,309.0,311.84686,311.84686,311.84686,311.84686,312.0,312.0,312.0,312.0,314.84686,314.84686,314.84686,314.84686,315.0,315.0,315.0,315.0,317.84686,317.84686,317.84686,317.84686,318.0,318.0,318.0,318.0,320.84686,320.84686,320.84686,320.84686,321.0,321.0,321.0,323.84686,323.84686,323.84686,324.0,324.0,324.0,324.0,326.84686,326.84686,326.84686,326.84686,327.0,327.0,327.0,327.0,329.84686,329.84686,329.84686,329.84686,330.0,330.0,330.0,330.0,332.84686,332.84686,332.84686,332.84686,333.0,333.0,333.0,333.0,335.84686,335.84686,335.84686,335.84686,336.0,336.0,336.0,336.0,338.84686,338.84686,338.84686,338.84686,339.0,339.0,339.0,339.0,341.84686,341.84686,341.84686,341.84686,342.0,342.0,342.0,342.0,344.84686,344.84686,344.84686,344.84686,345.0,345.0,345.0,345.0,347.84686,347.84686,347.84686,347.84686,348.0,348.0,348.0,348.0,350.84686,350.84686,350.84686,350.84686,351.0,351.0,351.0,351.0,353.84686,353.84686,353.84686,353.84686,354.0,354.0,354.0,354.0,356.84686,356.84686,356.84686,356.84686,357.0,357.0,357.0,357.0,359.84686,359.84686,359.84686,359.84686,360.0,360.0,360.0,360.0,362.84686,362.84686,362.84686,362.84686,363.0,363.0,363.0,363.0,365.84686,365.84686,365.84686,365.84686,366.0,366.0,366.0,366.0,368.84686,368.84686,368.84686,368.84686,369.0,369.0,369.0,369.0,371.84686,371.84686,371.84686,371.84686,372.0,372.0,372.0,372.0,374.84686,374.84686,374.84686,374.84686,375.0,375.0,375.0,375.0,377.84686,377.84686,377.84686,377.84686,378.0,378.4,378.79688,379.19687,379.59375,380.9875,380.9875,380.9875,380.9875,380.9875,381.0,381.0,381.0,381.0,385.26562,385.26562,385.26562,385.26562,385.5,385.5,386.91876,386.91876,387.0,387.0,387.0,387.0,389.84686,389.84686,389.84686,389.84686,390.0,390.0,390.0,390.0,393.0,393.0,393.0,393.0,393.0,393.4,393.79688,394.19687,395.9875,395.9875,395.9875,395.9875,396.0,396.4,396.79688,397.19687,398.2375,398.2375,398.2375,398.2375,398.25,398.95312,399.0,399.70312,399.75,400.45312,400.5,401.20312,401.25,401.95312,402.0,402.70312,402.75,403.45312,403.5,404.20312,404.25,404.95312,405.0,405.70312,405.75,406.45312,406.5,407.20312,407.25,407.95312,408.0,408.70312,408.75,409.45312,409.5,410.20312,410.25,410.95312,411.0,411.70312,411.75,412.45312,412.5,413.20312,413.25,413.95312,414.0,414.7375,414.75,415.4875,415.5,416.2375,416.25,416.9875,417.0,419.9875,420.0,420.35312,420.375,420.72812,420.75,421.10312,421.125,421.47812,421.5,421.85312,421.875,422.22812,422.25,422.60312,422.625,422.97812,423.0,423.35312,423.375,423.72812,423.75,424.10312,424.125,424.47812,424.5,424.85312,424.875,425.22812,425.25,425.60312,425.625,434.51874,435.0,437.9875,454.5,454.5,454.5125,454.96875,455.0031,455.47186,455.4969,455.96564,456.0,456.0,456.0125,456.46875,456.5031,456.97186,456.9969,457.46564,457.5,457.5,457.5125,457.96875,458.0031,458.47186,458.4969,458.96564,459.0,459.0,459.0125,459.46875,459.5031,459.97186,459.9969,460.46564,460.5,460.5,460.5125,460.96875,461.0031,461.47186,461.4969,461.96564,462.0,462.0,462.0125,462.46875,462.5031,462.97186,462.9969,463.46564,463.5,463.5,463.5125,463.96875,464.0031,464.47186,464.4969,464.96564,465.0,465.0,465.0125,465.46875,465.5031,465.97186,465.9969,466.46564,466.5,466.5,466.5125,466.96875,467.0031,467.47186,467.4969,467.96564,468.0,468.0,468.0125,468.46875,468.5031,468.97186,468.9969,469.46564,469.5,469.5,469.5125,469.96875,470.0031,470.47186,470.4969,470.96564,471.0,471.0,471.0125,471.46875,471.5031,471.97186,471.9969,472.46564,472.5,472.5,472.5125,472.96875,473.0031,473.47186,473.4969,473.96564,474.0,474.0,474.0125,474.46875,474.5031,474.97186,474.9969,475.46564,475.5,475.5,475.5125,475.96875,476.0031,476.47186,476.4969,476.96564,477.0,477.0,477.0125,477.46875,477.5031,477.97186,477.9969,478.46564,478.5,478.5,478.5125,478.96875,479.0031,479.47186,479.4969,479.96564,480.0,480.0,480.0125,480.46875,480.5031,480.97186,480.9969,481.46564,481.5,481.5,481.5125,481.96875,482.0031,482.47186,482.4969,482.96564,483.0,483.0,483.0125,483.46875,483.5031,483.97186,483.9969,484.46564,484.5,484.5,484.5125,484.96875,485.0031,485.47186,485.4969,485.96564,486.0,486.0,486.0125,486.46875,486.5031,486.97186,486.9969,487.46564,487.5,487.5,487.5125,487.96875,488.0031,488.47186,488.4969,488.96564,489.0,489.0,489.0125,489.46875,489.5031,489.97186,489.9969,490.46564,490.5,490.5,490.5125,490.96875,491.0031,491.47186,491.4969,491.96564,492.0,492.0,492.0125,492.46875,492.5031,492.97186,492.9969,493.46564,493.5,493.5,493.5125,493.96875,494.0031,494.47186,494.4969,494.96564,495.0,495.0,495.0125,495.46875,495.5031,495.97186,495.9969,496.46564,496.5,496.5,496.5125,496.96875,497.0031,497.47186,497.4969,497.96564,498.0,498.0,498.0125,498.46875,498.5031,498.97186,498.9969,499.46564,499.5,499.5,499.5125,499.96875,500.0031,500.47186,500.4969,500.96564,501.0,501.0,501.0125,501.46875,501.5031,501.97186,501.9969,502.46564,502.5,502.5,502.5125,502.96875,503.0031,503.47186,503.4969,503.96564,504.0,504.0,504.0125,504.46875,504.5031,504.97186,504.9969,505.46564,505.5,505.5,505.5125,505.96875,506.0031,506.47186,506.4969,506.96564,507.0,507.0,507.0125,507.46875,507.5031,507.97186,507.9969,508.46564,508.5,508.5,508.5125,508.96875,509.0031,509.47186,509.4969,509.96564,510.0,510.0,510.0125,510.46875,510.5031,510.97186,510.9969,511.46564,511.5,511.5,511.5125,511.96875,512.0031,512.47186,512.4969,512.96564,513.0,513.0,513.0125,513.46875,513.5031,513.97186,513.9969,514.46564,514.5,514.5,514.5125,514.96875,515.0031,515.47186,515.4969,515.96564,516.0,516.0,516.0125,516.46875,516.5031,516.97186,516.9969,517.46564,517.5,517.5,517.5125,517.96875,518.0031,518.47186,518.4969,518.96564,519.0,519.0,519.0125,519.46875,519.5031,519.97186,519.9969,520.46564,520.5,520.5,520.5125,520.85315,520.875,521.22815,521.25,521.60315,521.625,521.97815,522.0,522.0,522.0125,522.35315,522.375,522.72815,522.75,523.10315,523.125,523.47815,523.5,523.5,523.5125,523.85315,523.875,524.22815,524.25,524.60315,524.625,524.97815,525.0,525.0,525.0125,525.35315,525.375,525.72815,525.75,526.10315,526.125,526.47815,526.5,526.5,526.5125,526.85315,526.875,527.22815,527.25,527.60315,527.625,527.97815,528.0,528.0,528.0125,528.35315,528.375,528.72815,528.75,529.10315,529.125,529.47815,529.5,529.5,529.5125,529.85315,529.875,530.22815,530.25,530.60315,530.625,530.97815,531.0,531.0,531.0125,531.35315,531.375,531.72815,531.75,532.10315,532.125,532.47815,532.5,532.5,532.5125,532.85315,532.875,533.22815,533.25,533.60315,533.625,533.97815,534.0,534.0,534.0125,534.35315,534.375,534.72815,534.75,535.10315,535.125,535.47815,535.5,535.5,535.5125,535.85315,535.875,536.22815,536.25,536.60315,536.625,536.97815,537.0,537.0,537.0125,537.35315,537.375,537.72815,537.75,538.10315,538.125,538.47815,538.5,538.5,538.5125,538.85315,538.875,539.22815,539.25,539.60315,539.625,539.97815,540.0,540.0,540.0125,540.35315,540.375,540.72815,540.75,541.10315,541.125,541.47815,541.5,541.5,541.5125,541.85315,541.875,542.22815,542.25,542.60315,542.625,542.97815,543.0,543.0,543.0125,543.35315,543.375,543.72815,543.75,544.10315,544.125,544.47815,544.5,544.5,544.5125,544.85315,544.875,545.22815,545.25,545.60315,545.625,545.97815,546.0,546.0,546.0125,546.35315,546.375,546.72815,546.75,547.10315,547.125,547.47815,547.5,547.5,547.5125,547.85315,547.875,548.22815,548.25,548.60315,548.625,548.97815,549.0,549.0,549.0125,549.35315,549.375,549.72815,549.75,550.10315,550.125,550.47815,550.5,550.5,550.5125,550.85315,550.875,551.22815,551.25,551.60315,551.625,551.97815,552.0,552.0,552.0125,552.35315,552.375,552.72815,552.75,553.10315,553.125,553.47815,553.5,553.5,553.5125,553.85315,553.875,554.22815,554.25,554.60315,554.625,554.97815,555.0,555.0,555.0125,555.35315,555.375,555.72815,555.75,556.10315,556.125,556.47815,556.5,556.5,556.5125,556.85315,556.875,557.22815,557.25,557.60315,557.625,557.97815,558.0,558.0,558.0125,558.35315,558.375,558.72815,558.75,559.10315,559.125,559.47815,559.5,559.5,559.5125,559.85315,559.875,560.22815,560.25,560.60315,560.625,560.97815,561.0,561.0,561.0125,561.35315,561.375,561.72815,561.75,562.10315,562.125,562.47815,562.5,562.5,562.5125,562.85315,562.875,563.22815,563.25,563.60315,563.625,563.97815,564.0,564.0,564.0125,564.35315,564.375,564.72815,564.75,565.10315,565.125,565.47815,565.5,565.5,565.5125,565.85315,565.875,566.22815,566.25,566.60315,566.625,566.97815,567.0,567.0,567.0125,567.35315,567.375,567.72815,567.75,568.10315,568.125,568.47815,568.5,568.5,568.5125,568.85315,568.875,569.22815,569.25,569.60315,569.625,569.97815,570.0,570.0,570.0125,570.35315,570.375,570.72815,570.75,571.10315,571.125,571.47815,571.5,571.5,571.5125,571.85315,571.875,572.22815,572.25,572.60315,572.625,572.97815,573.0,573.0,573.0125,573.35315,573.375,573.72815,573.75,574.10315,574.125,574.47815,574.5,574.5,574.5125,574.85315,574.875,575.22815,575.25,575.60315,575.625,575.97815,576.0,576.0,576.0125,576.35315,576.375,576.72815,576.75,577.10315,577.125,577.47815,577.5,577.5,577.5125,577.85315,577.875,578.22815,578.25,578.60315,578.625,578.97815,579.0,579.0,579.0125,579.35315,579.375,579.72815,579.75,580.10315,580.125,580.47815,580.5,580.5,580.5125,580.85315,580.875,581.22815,581.25,581.60315,581.625,581.97815,582.0,582.0,582.0125,582.35315,582.375,582.72815,582.75,583.10315,583.125,583.47815,583.5,583.5,583.5125,583.85315,583.875,584.22815,584.25,584.60315,584.625,584.97815,585.0,585.0,585.0125,585.35315,585.375,585.72815,585.75,586.10315,586.125,586.47815,586.5,586.5,586.5125,586.85315,586.875,587.22815,587.25,587.60315,587.625,587.97815,588.0,588.0,588.0125,588.35315,588.375,588.72815,588.75,589.10315,589.125,589.47815,589.5,589.5,589.5125,589.85315,589.875,590.22815,590.25,590.60315,590.625,590.97815,591.0,591.0,591.0125,591.35315,591.375,591.72815,591.75,592.10315,592.125,592.47815,592.5,592.5,592.5125,592.85315,592.875,593.22815,593.25,593.60315,593.625,593.97815,594.0,594.0,594.0125,594.35315,594.375,594.72815,594.75,595.10315,595.125,595.47815,595.5,595.5,595.5125,595.85315,595.875,596.22815,596.25,596.60315,596.625,596.97815,597.0,597.0,597.0125,597.35315,597.375,597.72815,597.75,598.10315,598.125,598.47815,598.5,598.5,598.5125,598.85315,598.875,599.22815,599.25,599.60315,599.625,599.97815,600.0,600.0,600.0125,600.35315,600.375,600.72815,600.75,601.10315,601.125,601.47815,601.5,601.5,601.5125,601.85315,601.875,602.22815,602.25,602.60315,602.625,602.97815,603.0,603.0,603.0125,603.35315,603.375,603.72815,603.75,604.10315,604.125,604.47815,604.5,604.5,604.5125,604.85315,604.875,605.22815,605.25,605.60315,605.625,605.97815,606.0,606.0,606.0125,606.35315,606.375,606.72815,606.75,607.10315,607.125,607.47815,607.5,607.5,607.5125,607.85315,607.875,608.22815,608.25,608.60315,608.625,608.97815,609.0,609.0,609.0125,609.35315,609.375,609.72815,609.75,610.10315,610.125,610.47815,610.5,610.5,610.5125,610.85315,610.875,611.22815,611.25,611.60315,611.625,611.97815,612.0,612.0,612.0125,612.35315,612.375,612.72815,612.75,613.10315,613.125,613.47815,613.5,613.5,613.5125,613.85315,613.875,614.22815,614.25,614.60315,614.625,614.97815,615.0,615.0,615.0125,615.35315,615.375,615.72815,615.75,616.10315,616.125,616.47815,616.5,616.5,616.5125,616.85315,616.875,617.22815,617.25,617.60315,617.625,617.97815,618.0,618.0,618.0125,618.35315,618.375,618.72815,618.75,619.10315,619.125,619.47815,619.5,619.5,619.5125,619.85315,619.875,620.22815,620.25,620.60315,620.625,620.97815,621.0,621.0,621.0125,621.35315,621.375,621.72815,621.75,622.10315,622.125,622.47815,622.5,622.5,622.5125,622.85315,622.875,623.22815,623.25,623.60315,623.625,623.97815,624.0,624.0,624.0125,624.35315,624.375,624.72815,624.75,625.10315,625.125,625.47815,625.5,625.5,625.5125,625.85315,625.875,626.22815,626.25,626.60315,626.625,626.97815,627.0,627.0,627.0125,627.35315,627.375,627.72815,627.75,628.10315,628.125,628.47815,628.5,628.5,628.5125,628.85315,628.875,629.22815,629.25,629.60315,629.625,629.97815,630.0,630.0,630.0125,630.35315,630.375,630.72815,630.75,631.10315,631.125,631.47815,631.5,631.5,631.5125,631.85315,631.875,632.22815,632.25,632.60315,632.625,632.97815,633.0,633.0,633.0125,633.35315,633.375,633.72815,633.75,634.10315,634.125,634.47815,634.5,634.5,634.5125,634.85315,634.875,635.22815,635.25,635.60315,635.625,635.97815,636.0,636.0,636.0125,636.35315,636.375,636.72815,636.75,637.10315,637.125,637.47815,637.5,637.5,637.5125,637.85315,637.875,638.22815,638.25,638.60315,638.625,638.97815,639.0,639.0,639.0125,639.35315,639.375,639.72815,639.75,640.10315,640.125,640.47815,640.5,640.5,640.5125,640.85315,640.875,641.22815,641.25,641.60315,641.625,641.97815,642.0,642.0,642.0125,642.35315,642.375,642.72815,642.75,643.10315,643.125,643.47815,643.5,643.5,643.5125,643.85315,643.875,644.22815,644.25,644.60315,644.625,644.97815,645.0,645.0,645.0125,645.35315,645.375,645.72815,645.75,646.10315,646.125,646.47815,646.5,646.5,646.5125,646.85315,646.875,647.22815,647.25,647.60315,647.625,647.97815,648.0,648.0,648.0125,648.35315,648.375,648.72815,648.75,649.10315,649.125,649.47815,649.5,649.5,649.5125,649.85315,649.875,650.22815,650.25,650.60315,650.625,650.97815,651.0,651.0,651.0125,651.35315,651.375,651.72815,651.75,652.10315,652.125,652.47815,652.5,652.5,652.5125,652.85315,652.875,653.22815,653.25,653.60315,653.625,653.97815,654.0,654.0,654.0125,654.35315,654.375,654.72815,654.75,655.10315,655.125,655.47815,655.5,655.5,655.5125,655.85315,655.875,656.22815,656.25,656.60315,656.625,656.97815,657.0,657.0,657.0125,657.35315,657.375,657.72815,657.75,658.10315,658.125,658.47815,658.5,658.5,658.5125,658.85315,658.875,659.22815,659.25,659.60315,659.625,659.97815,660.0,660.0,660.0125,660.35315,660.375,660.72815,660.75,661.10315,661.125,661.47815,661.5,661.5,661.5125,661.85315,661.875,662.22815,662.25,662.60315,662.625,662.97815,663.0,663.0,663.0125,663.35315,663.375,663.72815,663.75,664.10315,664.125,664.47815,664.5,664.5,664.5125,664.85315,664.875,665.22815,665.25,665.60315,665.625,665.97815,666.0,666.0,666.0125,666.35315,666.375,666.72815,666.75,667.10315,667.125,667.47815,667.5,667.5,667.5125,667.85315,667.875,668.22815,668.25,668.60315,668.625,668.97815,669.0,669.0,669.0125,669.35315,669.375,669.72815,669.75,670.10315,670.125,670.47815,670.5,670.5,670.5125,670.85315,670.875,671.22815,671.25,671.60315,671.625,671.97815,672.0,672.0,672.0125,672.35315,672.375,672.72815,672.75,673.10315,673.125,673.47815,673.5,673.5,673.5125,673.85315,673.875,674.22815,674.25,674.60315,674.625,674.97815,675.0,675.0,675.0125,675.35315,675.375,675.72815,675.75,676.10315,676.125,676.47815,676.5,676.5,676.5125,676.85315,676.875,677.22815,677.25,677.60315,677.625,677.97815,678.0,678.0,678.0125,678.35315,678.375,678.72815,678.75,679.10315,679.125,679.47815,679.5,679.5,679.5125,679.85315,679.875,680.22815,680.25,680.60315,680.625,680.97815,681.0,681.0,681.0125,681.35315,681.375,681.72815,681.75,682.10315,682.125,682.47815,682.5,682.5,682.5125,682.85315,682.875,683.22815,683.25,683.60315,683.625,683.97815,684.0,684.0,684.0125,684.35315,684.375,684.72815,684.75,685.10315,685.125,685.47815,685.5,685.5,685.5125,685.85315,685.875,686.22815,686.25,686.60315,686.625,686.97815,687.0,687.0,687.0125,687.35315,687.375,687.72815,687.75,688.10315,688.125,688.47815,688.5,688.5,688.5125,688.85315,688.875,689.22815,689.25,689.60315,689.625,689.97815,690.0,690.0,690.0125,690.35315,690.375,690.72815,690.75,691.10315,691.125,691.47815,691.5,691.5,691.5125,691.85315,691.875,692.22815,692.25,692.60315,692.625,692.97815,693.0,693.0,693.0125,693.35315,693.375,693.72815,693.75,694.10315,694.125,694.47815,694.5,694.5,694.5125,694.85315,694.875,695.22815,695.25,695.60315,695.625,695.97815,696.0,696.0,696.0125,696.35315,696.375,696.72815,696.75,697.10315,697.125,697.47815,697.5,697.5,697.5125,697.85315,697.875,698.22815,698.25,698.60315,698.625,698.97815,699.0,699.0,699.0125,699.35315,699.375,699.72815,699.75,700.10315,700.125,700.47815,700.5,700.5,700.5125,700.85315,700.875,701.22815,701.25,701.60315,701.625,701.97815,702.0,702.0,702.0125,702.35315,702.375,702.72815,702.75,703.10315,703.125,703.47815,703.5,703.5,703.5125,703.85315,703.875,704.22815,704.25,704.60315,704.625,704.97815,705.0,705.0,705.0125,705.35315,705.375,705.72815,705.75,706.10315,706.125,706.47815,706.5,706.5,706.5125,706.85315,706.875,707.22815,707.25,707.60315,707.625,707.97815,708.0,708.0,708.0125,708.35315,708.375,708.72815,708.75,709.10315,709.125,709.47815,709.5,709.5,709.5125,709.85315,709.875,710.22815,710.25,710.60315,710.625,710.97815,711.0,711.0,711.0125,711.35315,711.375,711.72815,711.75,712.10315,712.125,712.47815,712.5,712.5,712.5125,712.85315,712.875,713.22815,713.25,713.60315,713.625,713.97815,714.0,714.0,714.0125,714.35315,714.375,714.72815,714.75,715.10315,715.125,715.47815,715.5,715.5,715.5125,715.85315,715.875,716.22815,716.25,716.60315,716.625,716.97815,717.0,717.0,717.0125,717.35315,717.375,717.72815,717.75,718.10315,718.125,718.47815,718.5,718.5,718.5125,718.85315,718.875,719.22815,719.25,719.60315,719.625,719.97815,720.0,720.0,720.0125,720.35315,720.375,720.72815,720.75,721.10315,721.125,721.47815,721.5,721.5,721.5125,721.85315,721.875,722.22815,722.25,722.60315,722.625,722.97815,723.0,723.0,723.0125,723.35315,723.375,723.72815,723.75,724.10315,724.125,724.47815,724.5,724.5,724.5125,724.85315,724.875,725.22815,725.25,725.60315,725.625,725.97815,726.0,726.0,726.0125,726.35315,726.375,726.72815,726.75,727.10315,727.125,727.47815,727.5,727.5,727.5125,727.85315,727.875,728.22815,728.25,728.60315,728.625,728.97815,729.0,729.0,729.0125,729.35315,729.375,729.72815,729.75,730.10315,730.125,730.47815,730.5,730.5,730.5125,730.85315,730.875,731.22815,731.25,731.60315,731.625,731.97815,732.0,732.0,732.0125,732.35315,732.375,732.72815,732.75,733.10315,733.125,733.47815,733.5,733.5,733.5125,733.85315,733.875,734.22815,734.25,734.60315,734.625,734.97815,735.0,735.0,735.0125,735.35315,735.375,735.72815,735.75,736.10315,736.125,736.47815,736.5,736.5,736.5125,736.85315,736.875,737.22815,737.25,737.60315,737.625,737.97815,738.0,738.0,738.0125,738.35315,738.375,738.72815,738.75,739.10315,739.125,739.47815,739.5,739.5,739.5125,739.85315,739.875,740.22815,740.25,740.60315,740.625,740.97815,741.0,741.0,741.0125,741.35315,741.375,741.72815,741.75,742.10315,742.125,742.47815,742.5,742.5,742.5125,742.85315,742.875,743.22815,743.25,743.60315,743.625,743.97815,744.0,744.0,744.0125,744.35315,744.375,744.72815,744.75,745.10315,745.125,745.47815,745.5,745.5,745.5125,745.85315,745.875,746.22815,746.25,746.60315,746.625,746.97815,747.0,747.0,747.0125,747.35315,747.375,747.72815,747.75,748.10315,748.125,748.47815,748.5,748.5,748.5125,748.85315,748.875,749.22815,749.25,749.60315,749.625,749.97815,750.0,750.0,750.0125,750.35315,750.375,750.72815,750.75,751.10315,751.125,751.47815,751.5,751.5,751.5125,751.85315,751.875,752.22815,752.25,752.60315,752.625,752.97815,753.0,753.0,753.0125,753.35315,753.375,753.72815,753.75,754.10315,754.125,754.47815,754.5,754.5,754.5125,754.85315,754.875,755.22815,755.25,755.60315,755.625,755.97815,756.0,756.0,756.0125,756.35315,756.375,756.72815,756.75,757.10315,757.125,757.47815,757.5,757.5,757.5125,757.85315,757.875,758.22815,758.25,758.60315,758.625,758.97815,759.0,759.0,759.0125,759.35315,759.375,759.72815,759.75,760.10315,760.125,760.47815,760.5,760.5,760.5125,760.85315,760.875,761.22815,761.25,761.60315,761.625,761.97815,762.0,762.0,762.0125,762.35315,762.375,762.72815,762.75,763.10315,763.125,763.47815,763.5,763.5,763.5125,763.85315,763.875,764.22815,764.25,764.60315,764.625,764.97815,765.0,765.0,765.0125,765.35315,765.375,765.72815,765.75,766.10315,766.125,766.47815,766.5,766.5,766.5125,766.85315,766.875,767.22815,767.25,767.60315,767.625,767.97815,768.0,768.0,768.0125,768.35315,768.375,768.72815,768.75,769.10315,769.125,769.47815,769.5,769.5,769.5125,769.85315,769.875,770.22815,770.25,770.60315,770.625,770.97815,771.0,771.0,771.0125,771.35315,771.375,771.72815,771.75,772.10315,772.125,772.47815,772.5,772.5,772.5125,772.85315,772.875,773.22815,773.25,773.60315,773.625,773.97815,774.0,774.0,774.0125,774.35315,774.375,774.72815,774.75,775.10315,775.125,775.47815,775.5,775.5,775.5125,775.85315,775.875,776.22815,776.25,776.60315,776.625,776.97815,777.0,777.0,777.0125,777.35315,777.375,777.72815,777.75,778.10315,778.125,778.47815,778.5,778.5,778.5125,778.85315,778.875,779.22815,779.25,779.60315,779.625,779.97815,780.0,780.0,780.0125,780.35315,780.375,780.72815,780.75,781.10315,781.125,781.47815,781.5,781.5,781.5125,781.85315,781.875,782.22815,782.25,782.60315,782.625,782.97815,783.0,783.0,783.0125,783.35315,783.375,783.72815,783.75,784.10315,784.125,784.47815,784.5,784.5,784.5125,784.85315,784.875,785.22815,785.25,785.60315,785.625,785.97815,786.0,786.0,786.0125,786.35315,786.375,786.72815,786.75,787.10315,787.125,787.47815,787.5,787.5,787.5125,787.85315,787.875,788.22815,788.25,788.60315,788.625,788.97815,789.0,789.0,789.0125,789.35315,789.375,789.72815,789.75,790.10315,790.125,790.47815,790.5,790.5,790.5125,790.85315,790.875,791.22815,791.25,791.60315,791.625,791.97815,792.0,792.0,792.0125,792.35315,792.375,792.72815,792.75,793.10315,793.125,793.47815,793.5,793.5,793.5125,793.85315,793.875,794.22815,794.25,794.60315,794.625,794.97815,795.0,795.0,795.0125,795.35315,795.375,795.72815,795.75,796.10315,796.125,796.47815,796.5,796.5,796.5125,796.85315,796.875,797.22815,797.25,797.60315,797.625,797.97815,798.0,798.0,798.0125,798.35315,798.375,798.72815,798.75,799.10315,799.125,799.47815,799.5,799.5,799.5125,799.85315,799.875,800.22815,800.25,800.60315,800.625,800.97815,801.0,801.0,801.0125,801.35315,801.375,801.72815,801.75,802.10315,802.125,802.47815,802.5,802.5,802.5125,802.85315,802.875,803.22815,803.25,803.60315,803.625,803.97815,804.0,804.0,804.0125,804.35315,804.375,804.72815,804.75,805.10315,805.125,805.47815,805.5,805.5,805.5125,805.85315,805.875,806.22815,806.25,806.60315,806.625,806.97815,807.0,807.0,807.0125,807.35315,807.375,807.72815,807.75,808.10315,808.125,808.47815,808.5,808.5,808.5125,808.85315,808.875,809.22815,809.25,809.60315,809.625,809.97815,810.0,810.0,810.0125,810.35315,810.375,810.72815,810.75,811.10315,811.125,811.47815,811.5,811.5,811.5125,811.85315,811.875,812.22815,812.25,812.60315,812.625,812.97815,813.0,813.0,813.0125,813.35315,813.375,813.72815,813.75,814.10315,814.125,814.47815,814.5,814.5,814.5125,814.85315,814.875,815.22815,815.25,815.60315,815.625,815.97815,816.0,816.0,816.0125,816.35315,816.375,816.72815,816.75,817.10315,817.125,817.47815,817.5,817.5,817.5125,817.85315,817.875,818.22815,818.25,818.60315,818.625,818.97815,819.0,819.0,819.0125,819.35315,819.375,819.72815,819.75,820.10315,820.125,820.47815,820.5,820.5,820.5125,820.85315,820.875,821.22815,821.25,821.60315,821.625,821.97815,822.0,822.0,822.0125,822.35315,822.375,822.72815,822.75,823.10315,823.125,823.47815,823.5,823.5,823.5125,823.85315,823.875,824.22815,824.25,824.60315,824.625,824.97815,825.0,825.0,825.0125,825.35315,825.375,825.72815,825.75,826.10315,826.125,826.47815,826.5,826.5,826.5125,826.85315,826.875,827.22815,827.25,827.60315,827.625,827.97815,828.0,828.0,828.0125,828.35315,828.375,828.72815,828.75,829.10315,829.125,829.47815,829.5,829.5,829.5125,829.85315,829.875,830.22815,830.25,830.60315,830.625,830.97815,831.0,831.0,831.0125,831.35315,831.375,831.72815,831.75,832.10315,832.125,832.47815,832.5,832.5,832.5125,832.85315,832.875,833.22815,833.25,833.60315,833.625,833.97815,834.0,834.0,834.0125,834.35315,834.375,834.72815,834.75,835.10315,835.125,835.47815,835.5,835.5,835.5125,835.85315,835.875,836.22815,836.25,836.60315,836.625,836.97815,837.0,837.0,837.0125,837.35315,837.375,837.72815,837.75,838.10315,838.125,838.47815,838.5,838.5,838.5125,838.85315,838.875,839.22815,839.25,839.60315,839.625,839.97815,840.0,840.0,840.0125,840.35315,840.375,840.72815,840.75,841.10315,841.125,841.47815,841.5,841.5,841.5125,841.85315,841.875,842.22815,842.25,842.60315,842.625,842.97815,843.0,843.0,843.0125,843.35315,843.375,843.72815,843.75,844.10315,844.125,844.47815,844.5,844.5,844.5125,844.85315,844.875,845.22815,845.25,845.60315,845.625,845.97815,846.0,846.0,846.0125,846.35315,846.375,846.72815,846.75,847.10315,847.125,847.47815,847.5,847.5,847.5125,847.85315,847.875,848.22815,848.25,848.60315,848.625,848.97815,849.0,849.0,849.0125,849.35315,849.375,849.72815,849.75,850.10315,850.125,850.47815,850.5,850.5,850.5125,850.85315,850.875,851.22815,851.25,851.60315,851.625,851.97815,852.0,852.0,852.0125,852.35315,852.375,852.72815,852.75,853.10315,853.125,853.47815,853.5,853.5,853.5125,853.85315,853.875,854.22815,854.25,854.60315,854.625,854.97815,855.0,855.0,855.0125,855.35315,855.375,855.72815,855.75,856.10315,856.125,856.47815,856.5,856.5,856.5125,856.85315,856.875,857.22815,857.25,857.60315,857.625,857.97815,858.0,858.0,858.0125,858.35315,858.375,858.72815,858.75,859.10315,859.125,859.47815,859.5,859.5,859.5125,859.85315,859.875,860.22815,860.25,860.60315,860.625,860.97815,861.0,861.0,861.0125,861.35315,861.375,861.72815,861.75,862.10315,862.125,862.47815,862.5,862.5,862.5125,862.85315,862.875,863.22815,863.25,863.60315,863.625,863.97815,864.0,864.0,864.0125,864.35315,864.375,864.72815,864.75,865.10315,865.125,865.47815,865.5,865.5,865.5125,865.85315,865.875,866.22815,866.25,866.60315,866.625,866.97815,867.0,867.0,867.0125,867.35315,867.375,867.72815,867.75,868.10315,868.125,868.47815,868.5,868.5,868.5125,868.85315,868.875,869.22815,869.25,869.60315,869.625,869.97815,870.0,870.0,870.0125,870.35315,870.375,870.72815,870.75,871.10315,871.125,871.47815,871.5,871.5,871.5125,871.85315,871.875,872.22815,872.25,872.60315,872.625,872.97815,873.0,873.0,873.0125,873.35315,873.375,873.72815,873.75,874.10315,874.125,874.47815,874.5,874.5,874.5125,874.85315,874.875,875.22815,875.25,875.60315,875.625,875.97815,876.0,876.0,876.0125,876.35315,876.375,876.72815,876.75,877.10315,877.125,877.47815,877.5,877.5,877.5125,877.85315,877.875,878.22815,878.25,878.60315,878.625,878.97815,879.0,879.0,879.0125,879.35315,879.375,879.72815,879.75,880.10315,880.125,880.47815,880.5,880.5,880.5125,880.85315,880.875,881.22815,881.25,881.60315,881.625,881.97815,882.0,882.0,882.0125,882.35315,882.375,882.72815,882.75,883.10315,883.125,883.47815,883.5,883.5,883.5125,883.85315,883.875,884.22815,884.25,884.60315,884.625,884.97815,885.0,885.0,885.0125,885.35315,885.375,885.72815,885.75,886.10315,886.125,886.47815,886.5,886.5,886.5125,886.85315,886.875,887.22815,887.25,887.60315,887.625,887.97815,888.0,888.0,888.0125,888.35315,888.375,888.72815,888.75,889.10315,889.125,889.47815,889.5,889.5,889.5125,889.85315,889.875,890.22815,890.25,890.60315,890.625,890.97815,891.0,891.0,891.0125,891.35315,891.375,891.72815,891.75,892.10315,892.125,892.47815,892.5,892.5,892.5125,892.85315,892.875,893.22815,893.25,893.60315,893.625,893.97815,894.0,894.0,894.0125,894.35315,894.375,894.72815,894.75,895.10315,895.125,895.47815,895.5,895.5,895.5125,895.85315,895.875,896.22815,896.25,896.60315,896.625,896.97815,897.0,897.0,897.0125,897.35315,897.375,897.72815,897.75,898.10315,898.125,898.47815,898.5,898.5,898.5125,898.85315,898.875,899.22815,899.25,899.60315,899.625,899.97815,900.0,900.0,900.0125,900.35315,900.375,900.72815,900.75,901.10315,901.125,901.47815,901.5,901.5,901.5125,901.85315,901.875,902.22815,902.25,902.60315,902.625,902.97815,903.0,903.0,903.0125,903.35315,903.375,903.72815,903.75,904.10315,904.125,904.47815,904.5,904.5,904.5125,904.85315,904.875,905.22815,905.25,905.60315,905.625,905.97815,906.0,906.0,906.0125,906.35315,906.375,906.72815,906.75,907.10315,907.125,907.47815,907.5,907.5,907.5125,907.85315,907.875,908.22815,908.25,908.60315,908.625,908.97815,909.0,909.0,909.0125,909.35315,909.375,909.72815,909.75,910.10315,910.125,910.47815,910.5,910.5,910.5125,910.85315,910.875,911.22815,911.25,911.60315,911.625,911.97815,912.0,912.0,912.0125,912.35315,912.375,912.72815,912.75,913.10315,913.125,913.47815,913.5,913.5,913.5125,913.85315,913.875,914.22815,914.25,914.60315,914.625,914.97815,915.0,915.0,915.0125,915.35315,915.375,915.72815,915.75,916.10315,916.125,916.47815,916.5,916.5,916.5125,916.85315,916.875,917.22815,917.25,917.60315,917.625,917.97815,918.0,918.0,918.0125,918.35315,918.375,918.72815,918.75,919.10315,919.125,919.47815,919.5,919.5,919.5125,919.85315,919.875,920.22815,920.25,920.60315,920.625,920.97815,921.0,921.0,921.0125,921.35315,921.375,921.72815,921.75,922.10315,922.125,922.47815,922.5,922.5,922.5125,922.85315,922.875,923.22815,923.25,923.60315,923.625,923.97815,924.0,924.0,924.0125,924.35315,924.375,924.72815,924.75,925.10315,925.125,925.47815,925.5,925.5,925.5125,925.85315,925.875,926.22815,926.25,926.60315,926.625,926.97815,927.0,927.0,927.0125,927.35315,927.375,927.72815,927.75,928.10315,928.125,928.47815,928.5,928.5,928.5125,928.85315,928.875,929.22815,929.25,929.60315,929.625,929.97815,930.0,930.0,930.0125,930.35315,930.375,930.72815,930.75,931.10315,931.125,931.47815,931.5,931.5,931.5125,931.85315,931.875,932.22815,932.25,932.60315,932.625,932.97815,933.0,933.0,933.0125,933.35315,933.375,933.72815,933.75,934.10315,934.125,934.47815,934.5,934.5,934.5125,934.85315,934.875,935.22815,935.25,935.60315,935.625,935.97815,936.0,936.0,936.0125,936.35315,936.375,936.72815,936.75,937.10315,937.125,937.47815,937.5,937.5,937.5125,937.85315,937.875,938.22815,938.25,938.60315,938.625,938.97815,939.0,939.0,939.0125,939.35315,939.375,939.72815,939.75,940.10315,940.125,940.47815,940.5,940.5,940.5125,940.85315,940.875,941.22815,941.25,941.60315,941.625,941.97815,942.0,942.0,942.0125,942.35315,942.375,942.72815,942.75,943.10315,943.125,943.47815,943.5,943.5,943.5125,943.85315,943.875,944.22815,944.25,944.60315,944.625,944.97815,945.0,945.0,945.0125,945.35315,945.375,945.72815,945.75,946.10315,946.125,946.47815,946.5,946.5,946.5125,946.85315,946.875,947.22815,947.25,947.60315,947.625,947.97815,948.0,948.0,948.0125,948.46875,948.5031,948.97186,948.9969,949.46564,949.5,949.5,949.5125,949.96875,950.0031,950.47186,950.4969,950.96564,951.0,951.0,951.0125,951.46875,951.5031,951.97186,951.9969,952.46564,952.5,952.5,952.5125,952.96875,953.0031,953.47186,953.4969,953.96564,954.0,954.0,954.0125,954.46875,954.5031,954.97186,954.9969,955.46564,955.5,955.5,955.5125,955.96875,956.0031,956.47186,956.4969,956.96564,957.0,957.95,957.9969,958.9469,959.0031,959.9406,960.0,960.95,960.9969,961.9469,962.0031,962.9406,963.0,963.95,963.9969,964.9469,965.0031,965.9406,966.0,966.95,966.9969,967.9469,968.0031,968.9406,969.0,969.95,969.9969,970.9469,971.0031,971.9406,972.0,972.95,972.9969,973.9469,974.0031,974.9406,975.0,975.95,975.9969,976.9469,977.0031,977.9406,978.0,978.95,978.9969,979.9469,980.0031,980.9406,981.0,981.95,981.9969,982.9469,983.0031,983.9406,984.0,984.95,984.9969,985.9469,986.0031,986.9406,987.0,987.95,987.9969,988.9469,989.0031,989.9406,990.0,990.95,990.9969,991.9469,992.0031,992.9406,993.0,993.95,993.9969,994.9469,995.0031,995.9406,996.0,996.95,996.9969,997.9469,998.0031,998.9406,999.0,999.95,999.9969,1000.9469,1001.0031,1001.9406,1002.0,1002.95,1002.9969,1003.9469,1004.0031,1004.9406,1005.0,1005.95,1005.9969,1006.9469,1007.0031,1007.9406,1008.0,1008.95,1008.9969,1009.9469,1010.0031,1010.9406,1011.0,1011.95,1011.9969,1012.9469,1013.0031,1013.9406,1014.0,1014.95,1014.9969,1015.9469,1016.0031,1016.9406,1017.0,1017.95,1017.9969,1018.9469,1019.0031,1019.9406,1020.0,1020.95,1020.9969,1021.9469,1022.0031,1022.9406,1023.0,1023.95,1023.9969,1024.9469,1025.0032,1025.9407,1026.0,1026.95,1026.9968,1027.9469,1028.0032,1028.9407,1029.0,1029.95,1029.9968,1030.9469,1031.0032,1031.9407,1032.0,1032.95,1032.9968,1033.9469,1034.0032,1034.9407,1035.0,1035.95,1035.9968,1036.9469,1037.0032,1037.9407,1038.0,1038.95,1038.9968,1039.9469,1040.0032,1040.9407,1041.0,1041.95,1041.9968,1042.9469,1043.0032,1043.9407,1044.0,1044.95,1044.9968,1045.9469,1046.0032,1046.9407,1047.0,1047.95,1047.9968,1048.9469,1049.0032,1049.9407,1050.0,1050.95,1050.9968,1051.9469,1052.0032,1052.9407,1053.0,1053.95,1053.9968,1054.9469,1055.0032,1055.9407,1056.0,1056.95,1056.9968,1057.9469,1058.0032,1058.9407,1059.0,1059.95,1059.9968,1060.9469,1061.0032,1061.9407,1062.0,1062.95,1062.9968,1063.9469,1064.0032,1064.9407,1065.0,1065.95,1065.9968,1066.9469,1067.0032,1067.9407,1068.0,1068.95,1068.9968,1069.9469,1070.0032,1070.9407,1071.0,1071.95,1071.9968,1072.9469,1073.0032,1073.9407,1074.0,1074.95,1074.9968,1075.9469,1076.0032,1076.9407,1077.0,1077.95,1077.9968,1078.9469,1079.0032,1079.9407,1080.0,1080.95,1080.9968,1081.9469,1082.0032,1082.9407,1083.0,1083.95,1083.9968,1084.9469,1085.0032,1085.9407,1086.0,1086.95,1086.9968,1087.9469,1088.0032,1088.9407,1089.0,1089.95,1089.9968,1090.9469,1091.0032,1091.9407,1092.0,1092.95,1092.9968,1093.9469,1094.0032,1094.9407,1095.0,1095.95,1095.9968,1096.9469,1097.0032,1097.9407,1098.0,1098.95,1098.9968,1099.9469,1100.0032,1100.9407,1101.0,1101.95,1101.9968,1102.9469,1103.0032,1103.9407,1104.0,1104.95,1104.9968,1105.9469,1106.0032,1106.9407,1107.0,1107.95,1107.9968,1108.9469,1109.0032,1109.9407,1110.0,1110.95,1110.9968,1111.9469,1112.0032,1112.9407,1113.0,1113.95,1113.9968,1114.9469,1115.0032,1115.9407,1116.0,1116.95,1116.9968,1117.9469,1118.0032,1118.9407,1119.0,1119.95,1119.9968,1120.9469,1121.0032,1121.9407,1122.0,1122.95,1122.9968,1123.9469,1124.0032,1124.9407,1125.0,1125.95,1125.9968,1126.9469,1127.0032,1127.9407,1128.0,1128.95,1128.9968,1129.9469,1130.0032,1130.9407,1131.0,1131.95,1131.9968,1132.9469,1133.0032,1133.9407,1134.0,1134.95,1134.9968,1135.9469,1136.0032,1136.9407,1137.0,1137.95,1137.9968,1138.9469,1139.0032,1139.9407,1140.0,1140.95,1140.9968,1141.9469,1142.0032,1142.9407,1143.0,1143.95,1143.9968,1144.9469,1145.0032,1145.9407,1146.0,1146.95,1146.9968,1147.9469,1148.0032,1148.9407,1149.0,1149.95,1149.9968,1150.9469,1151.0032,1151.9407,1152.0,1152.95,1152.9968,1153.9469,1154.0032,1154.9407,1155.0,1155.95,1155.9968,1156.9469,1157.0032,1157.9407,1158.0,1158.95,1158.9968,1159.9469,1160.0032,1160.9407,1161.0,1161.95,1161.9968,1162.9469,1163.0032,1163.9407,1164.0,1164.95,1164.9968,1165.9469,1166.0032,1166.9407,1167.0,1167.95,1167.9968,1168.9469,1169.0032,1169.9407,1170.0,1170.95,1170.9968,1171.9469,1172.0032,1172.9407,1173.0,1173.95,1173.9968,1174.9469,1175.0032,1175.9407,1176.0,1176.95,1176.9968,1177.9469,1178.0032,1178.9407,1179.0,1179.95,1179.9968,1180.9469,1181.0032,1181.9407,1182.0,1182.95,1182.9968,1183.9469,1184.0032,1184.9407,1185.0,1185.95,1185.9968,1186.9469,1187.0032,1187.9407,1188.0,1188.95,1188.9968,1189.9469,1190.0032,1190.9407,1191.0,1191.95,1191.9968,1192.9469,1193.0032,1193.9407,1194.0,1194.95,1194.9968,1195.9469,1196.0032,1196.9407,1197.0,1197.95,1197.9968,1198.9469,1199.0032,1199.9407,1200.0,1200.95,1200.9968,1201.9469,1202.0032,1202.9407,1203.0,1203.95,1203.9968,1204.9469,1205.0032,1205.9407,1206.0,1206.95,1206.9968,1207.9469,1208.0032,1208.9407,1209.0,1210.4187,1210.5,1211.9187,1212.0,1214.8469,1215.0,1217.8469,1218.0,1219.4187,1219.5,1220.9187,1221.0,1222.4187,1222.5,1223.9187,1224.0,1225.4187,1225.5,1226.9187,1227.0,1228.4187,1228.5,1229.9187,1230.0,1231.4187,1231.5,1232.9187,1233.0,1234.4187,1234.5,1235.9187,1236.0,1237.4187,1237.5,1238.9187,1239.0,1240.4187,1240.5,1241.9187,1242.0,1243.4187,1243.5,1244.9187,1245.0,1246.4187,1246.5,1247.9187,1248.0,1249.4187,1249.5,1250.9187,1251.0,1252.4187,1252.5,1253.9187,1254.0,1255.4187,1255.5,1256.9187,1257.0,1258.4187,1258.5,1259.9187,1260.0,1261.4187,1261.5,1262.9187,1263.0,1264.4187,1264.5,1265.9187,1266.0,1267.4187,1267.5,1268.9187,1269.0,1270.4187,1270.5,1271.9187,1272.0,1273.4187,1273.5,1274.9187,1275.0,1276.4187,1276.5,1277.9187,1278.0,1279.4187,1279.5,1280.9187,1281.0,1282.4187,1282.5,1283.9187,1284.0,1285.4187,1285.5,1286.9187,1287.0,1288.4187,1288.5,1289.9187,1290.0,1291.4187,1291.5,1292.9187,1293.0,1294.4187,1294.5,1295.9187,1296.0,1297.4187,1297.5,1298.9187,1299.0,1300.4187,1300.5,1301.9187,1302.0,1303.4187,1303.5,1304.9187,1305.0,1306.4187,1306.5,1307.9187,1308.0,1309.4187,1309.5,1310.9187,1311.0,1312.4187,1312.5,1313.9187,1314.0,1314.0,1316.8469,1316.8469,1317.0,1317.0,1318.4187,1318.4187,1318.5,1319.9187,1320.0,1320.0,1321.4187,1321.4187,1321.5,1322.9187,1323.0,1323.0,1324.4187,1324.4187,1324.5,1325.9187,1326.0,1326.0,1327.4187,1327.4187,1327.5,1328.9187,1329.0,1329.0,1330.4187,1330.4187,1330.5,1331.9187,1332.0,1332.0,1333.4187,1333.4187,1333.5,1334.9187,1335.0,1335.0,1336.4187,1336.4187,1336.5,1337.9187,1338.0,1338.0,1339.4187,1339.4187,1339.5,1340.9187,1341.0,1341.0,1342.4187,1342.4187,1342.5,1343.9187,1344.0,1344.0,1345.4187,1345.4187,1345.5,1346.9187,1347.0,1348.4187,1348.5,1349.9187,1350.0,1351.4187,1351.5,1352.9187,1353.0,1354.4187,1354.5,1355.9187,1356.0,1357.4187,1357.5,1358.9187,1359.0,1359.0125,1360.5,1361.9187,1362.0,1362.0,1363.4187,1363.5,1364.8469,1364.9187,1365.0,1365.0,1366.4187,1366.5,1367.8469,1367.9187,1368.0,1368.0,1369.4187,1369.5,1370.8469,1370.9187,1371.0,1371.0,1372.4187,1372.5,1373.8469,1373.9187,1374.0,1374.0,1375.4187,1375.5,1376.8469,1376.9187,1377.0,1377.0,1378.4187,1378.5,1379.8469,1379.9187,1380.0,1380.0,1381.4187,1381.5,1382.8469,1382.9187,1383.0,1383.0,1384.4187,1384.5,1385.8469,1385.9187,1386.0,1386.0,1387.4187,1387.5,1388.8469,1388.9187,1389.0,1389.0,1390.4187,1390.5,1391.8469,1391.9187,1392.0,1392.0,1393.4187,1393.5,1394.8469,1394.9187,1395.0,1395.0,1396.4187,1396.5,1397.8469,1397.9187,1398.0,1398.0,1399.4187,1399.5,1400.8469,1400.9187,1401.0,1401.0,1402.4187,1402.5,1403.8469,1403.9187,1404.0,1404.0,1405.4187,1405.5,1406.8469,1406.9187,1407.0,1407.0,1408.4187,1408.5,1409.8469,1409.9187,1410.0,1410.0,1411.4187,1411.5,1412.8469,1412.9187,1413.0,1413.0,1414.4187,1414.5,1415.8469,1415.9187,1416.0,1416.0,1417.4187,1417.5,1418.8469,1418.9187,1419.0,1419.0,1420.4187,1420.5,1421.8469,1421.9187,1422.0,1422.0,1422.0,1423.4187,1423.4187,1423.5,1423.5,1424.8469,1424.9187,1424.9187,1425.0,1425.0,1425.0,1426.4187,1426.4187,1426.5,1426.5,1427.8469,1427.9187,1427.9187,1428.0,1428.0,1428.0,1429.4187,1429.4187,1429.5,1429.5,1430.2031,1430.2031,1430.25,1430.25,1430.8469,1430.9531,1430.9531,1431.0,1431.0,1431.0,1432.4187,1432.4187,1432.5,1432.5,1433.2031,1433.2031,1433.25,1433.25,1433.8469,1433.9531,1433.9531,1434.0,1434.0,1434.0,1435.4187,1435.4187,1435.5,1435.5,1436.2031,1436.2031,1436.25,1436.25,1436.8469,1436.9531,1436.9531,1437.0,1437.0,1437.0,1438.4187,1438.4187,1438.5,1438.5,1439.2031,1439.2031,1439.25,1439.25,1439.8469,1439.9531,1439.9531,1440.0,1440.0,1440.0,1440.0,1441.4187,1441.4187,1441.4187,1441.5,1441.5,1441.5,1442.2031,1442.2031,1442.2031,1442.25,1442.25,1442.25,1442.8469,1442.9531,1442.9531,1442.9531,1443.0,1443.0,1443.0,1443.0,1444.4187,1444.4187,1444.4187,1444.5,1444.5,1444.5,1444.9688,1444.9688,1444.9688,1445.0032,1445.0032,1445.0032,1445.4719,1445.4719,1445.4719,1445.4968,1445.4968,1445.4968,1445.8469,1445.9656,1445.9656,1445.9656,1446.0,1446.0,1446.0,1446.0,1447.4187,1447.4187,1447.4187,1447.5,1447.5,1447.5,1447.9688,1447.9688,1447.9688,1448.0032,1448.0032,1448.0032,1448.4719,1448.4719,1448.4719,1448.4968,1448.4968,1448.4968,1448.8469,1448.9656,1448.9656,1448.9656,1449.0,1449.0,1449.0,1449.0,1451.8469,1451.8469,1451.8469,1451.8469,1452.0,1452.0,1452.0,1452.0,1454.8469,1454.8469,1454.8469,1454.8469,1455.0,1455.0,1455.0,1455.0,1457.8469,1457.8469,1457.8469,1457.8469,1458.0,1458.0,1458.0,1458.0,1460.8469,1460.8469,1460.8469,1460.8469,1461.0,1461.0,1461.0,1461.0,1463.8469,1463.8469,1463.8469,1463.8469,1464.0,1464.0,1464.0,1464.0,1466.8469,1466.8469,1466.8469,1466.8469,1467.0,1467.0,1467.0,1467.0,1469.8469,1469.8469,1469.8469,1469.8469,1470.0,1470.0,1470.0,1470.0,1472.8469,1472.8469,1472.8469,1472.8469,1473.0,1473.0,1473.0,1473.0,1475.8469,1475.8469,1475.8469,1475.8469,1476.0,1476.0,1476.0,1476.0,1478.8469,1478.8469,1478.8469,1478.8469,1479.0,1479.0,1479.0,1479.0,1481.8469,1481.8469,1481.8469,1481.8469,1482.0,1482.0,1482.4688,1482.5032,1482.9719,1482.9968,1483.4656,1483.5,1483.9688,1484.0032,1484.4719,1484.4968,1484.8469,1484.9656,1485.0,1485.0,1485.4688,1485.5032,1485.9719,1485.9968,1486.4656,1486.5,1486.9688,1487.0032,1487.4719,1487.4968,1487.8469,1487.9656,1488.0,1488.0,1488.4688,1488.5032,1488.9719,1488.9968,1489.4656,1489.5,1489.9688,1490.0032,1490.4719,1490.4968,1490.8469,1490.9656,1491.0,1491.0,1491.4688,1491.5032,1491.9719,1491.9968,1492.4656,1492.5,1492.9688,1493.0032,1493.4719,1493.4968,1493.8469,1493.9656,1494.0,1494.0,1494.4688,1494.5032,1494.9719,1494.9968,1495.4656,1495.5,1495.9688,1496.0032,1496.4719,1496.4968,1496.8469,1496.9656,1497.0,1497.0,1497.4688,1497.5032,1497.9719,1497.9968,1498.4656,1498.5,1498.9688,1499.0032,1499.4719,1499.4968,1499.8469,1499.9656,1500.0,1500.0,1500.4688,1500.5032,1500.9719,1500.9968,1501.4656,1501.5,1501.9688,1502.0032,1502.4719,1502.4968,1502.8469,1502.9656,1503.0,1503.0,1503.4688,1503.5032,1503.9719,1503.9968,1504.4656,1504.5,1504.9688,1505.0032,1505.4719,1505.4968,1505.8469,1505.9656,1506.0,1506.0,1506.4688,1506.5032,1506.9719,1506.9968,1507.4656,1507.5,1507.9688,1508.0032,1508.4719,1508.4968,1508.8469,1508.9656,1509.0,1509.0,1509.4688,1509.5032,1509.9719,1509.9968,1510.4656,1510.5,1510.9688,1511.0032,1511.4719,1511.4968,1511.8469,1511.9656,1512.0,1512.0,1512.4688,1512.5032,1512.9719,1512.9968,1513.4656,1513.5,1513.9688,1514.0032,1514.4719,1514.4968,1514.8469,1514.9656,1515.0,1515.0,1515.4688,1515.5032,1515.9719,1515.9968,1516.4656,1516.5,1516.9688,1517.0032,1517.4719,1517.4968,1517.8469,1517.9656,1518.0,1518.0,1518.4688,1518.5032,1518.9719,1518.9968,1519.4656,1519.5,1519.9688,1520.0032,1520.4719,1520.4968,1520.8469,1520.9656,1521.0,1521.0,1521.4688,1521.5032,1521.9719,1521.9968,1522.4656,1522.5,1522.9688,1523.0032,1523.4719,1523.4968,1523.8469,1523.9656,1524.0,1524.0,1524.4688,1524.5032,1524.9719,1524.9968,1525.4656,1525.5,1525.9688,1526.0032,1526.4719,1526.4968,1526.8469,1526.9656,1527.0,1527.0,1527.4688,1527.5032,1527.9719,1527.9968,1528.4656,1528.5,1528.9688,1529.0032,1529.4719,1529.4968,1529.8469,1529.9656,1530.0,1530.0,1530.4688,1530.5032,1530.9719,1530.9968,1531.4656,1531.5,1531.9688,1532.0032,1532.4719,1532.4968,1532.8469,1532.9656,1533.0,1533.0,1533.4688,1533.5032,1533.9719,1533.9968,1534.4656,1534.5,1534.9688,1535.0032,1535.4719,1535.4968,1535.8469,1535.9656,1536.0,1536.0,1536.4688,1536.5032,1536.9719,1536.9968,1537.4656,1537.5,1537.9688,1538.0032,1538.4719,1538.4968,1538.8469,1538.9656,1539.0,1539.0,1539.4688,1539.5032,1539.9719,1539.9968,1540.4656,1540.5,1540.9688,1541.0032,1541.4719,1541.4968,1541.8469,1541.9656,1542.0,1542.0,1542.4688,1542.5032,1542.9719,1542.9968,1543.4656,1543.5,1543.9688,1544.0032,1544.4719,1544.4968,1544.8469,1544.9656,1545.0,1545.0,1545.4688,1545.5032,1545.9719,1545.9968,1546.4656,1546.5,1546.9688,1547.0032,1547.4719,1547.4968,1547.8469,1547.9656,1548.0,1548.0,1548.4688,1548.5032,1548.9719,1548.9968,1549.4656,1549.5,1549.9688,1550.0032,1550.4719,1550.4968,1550.8469,1550.9656,1551.0,1551.0,1551.4688,1551.5032,1551.9719,1551.9968,1552.4656,1552.5,1552.9688,1553.0032,1553.4719,1553.4968,1553.8469,1553.9656,1554.0,1554.0,1554.4688,1554.5032,1554.9719,1554.9968,1555.4656,1555.5,1555.9688,1556.0032,1556.4719,1556.4968,1556.8469,1556.9656,1557.0,1557.0,1557.4688,1557.5032,1557.9719,1557.9968,1558.4656,1558.5,1558.9688,1559.0032,1559.4719,1559.4968,1559.8469,1559.9656,1560.0,1560.0,1560.4688,1560.5032,1560.9719,1560.9968,1561.4656,1561.5,1561.9688,1562.0032,1562.4719,1562.4968,1562.8469,1562.9656,1563.0,1563.0,1563.4688,1563.5032,1563.9719,1563.9968,1564.4656,1564.5,1564.9688,1565.0032,1565.4719,1565.4968,1565.8469,1565.9656,1566.0,1566.0,1566.4688,1566.5032,1566.9719,1566.9968,1567.4656,1567.5,1567.9688,1568.0032,1568.4719,1568.4968,1568.8469,1568.9656,1569.0,1569.0,1569.4688,1569.5032,1569.9719,1569.9968,1570.4656,1570.5,1570.9688,1571.0032,1571.4719,1571.4968,1571.8469,1571.9656,1572.0,1572.0,1572.4688,1572.5032,1572.9719,1572.9968,1573.4656,1573.5,1573.9688,1574.0032,1574.4719,1574.4968,1574.8469,1574.9656,1575.0,1575.0,1575.4688,1575.5032,1575.9719,1575.9968,1576.4656,1576.5,1576.9688,1577.0032,1577.4719,1577.4968,1577.8469,1577.9656,1578.0,1578.0,1578.4688,1578.5032,1578.9719,1578.9968,1579.4656,1579.5,1579.9688,1580.0032,1580.4719,1580.4968,1580.8469,1580.9656,1581.0,1581.0,1581.4688,1581.5032,1581.9719,1581.9968,1582.4656,1582.5,1582.9688,1583.0032,1583.4719,1583.4968,1583.8469,1583.9656,1584.0,1584.0,1584.4688,1584.5032,1584.9719,1584.9968,1585.4656,1585.5,1585.9688,1586.0032,1586.4719,1586.4968,1586.8469,1586.9656,1587.0,1587.0,1587.4688,1587.5032,1587.9719,1587.9968,1588.4656,1588.5,1588.9688,1589.0032,1589.4719,1589.4968,1589.8469,1589.9656,1590.0,1590.0,1590.4688,1590.5032,1590.9719,1590.9968,1591.4656,1591.5,1591.9688,1592.0032,1592.4719,1592.4968,1592.8469,1592.9656,1593.0,1593.0,1593.0125,1593.3531,1593.375,1593.7281,1593.75,1594.1031,1594.125,1594.4781,1594.5,1594.5,1594.5125,1594.8531,1594.875,1595.2281,1595.25,1595.6031,1595.625,1595.9781,1596.0,1596.0,1596.0125,1596.3531,1596.375,1596.7281,1596.75,1597.1031,1597.125,1597.4781,1597.5,1597.5,1597.5125,1597.8531,1597.875,1598.2281,1598.25,1598.6031,1598.625,1598.9781,1599.0,1599.0,1599.0125,1599.3531,1599.375,1599.7281,1599.75,1600.1031,1600.125,1600.4781,1600.5,1600.5,1600.5125,1600.8531,1600.875,1601.2281,1601.25,1601.6031,1601.625,1601.9781,1602.0,1602.0,1602.0125,1602.2344,1602.2468,1602.4812,1602.5032,1602.7281,1602.75,1602.9844,1602.9968,1602.9968,1603.0094,1603.2312,1603.2532,1603.4781,1603.5,1603.7344,1603.7468,1603.9812,1604.0032,1604.0032,1604.0156,1604.2281,1604.25,1604.4844,1604.4968,1604.7312,1604.7532,1604.9781,1605.0,1605.0,1605.0125,1605.2344,1605.2468,1605.4812,1605.5032,1605.7281,1605.75,1605.9844,1605.9968,1605.9968,1606.0094,1606.2312,1606.2532,1606.4781,1606.5,1606.7344,1606.7468,1606.9812,1607.0032,1607.0032,1607.0156,1607.2281,1607.25,1607.4844,1607.4968,1607.7312,1607.7532,1607.9781,1608.0,1608.0,1608.0125,1608.2344,1608.2468,1608.4812,1608.5032,1608.7281,1608.75,1608.9844,1608.9968,1608.9968,1609.0094,1609.2312,1609.2532,1609.4781,1609.5,1609.7344,1609.7468,1609.9812,1610.0032,1610.0032,1610.0156,1610.2281,1610.25,1610.4844,1610.4968,1610.7312,1610.7532,1610.9781,1611.0,1611.0,1611.0125,1611.2344,1611.2468,1611.4812,1611.5032,1611.7281,1611.75,1611.9844,1611.9968,1611.9968,1612.0094,1612.2312,1612.2532,1612.4781,1612.5,1612.7344,1612.7468,1612.9812,1613.0032,1613.0032,1613.0156,1613.2281,1613.25,1613.4844,1613.4968,1613.7312,1613.7532,1614.0,1614.0,1614.0125,1614.2344,1614.2468,1614.4812,1614.4938,1614.5032,1614.75,1614.75,1614.9844,1614.9968,1614.9968,1615.0094,1615.2312,1615.2532,1615.4781,1615.5,1615.7344,1615.7468,1615.9812,1616.0032,1616.0032,1616.0156,1616.2281,1616.25,1616.4844,1616.4968,1616.7312,1616.7532,1616.9781,1617.0,1617.0,1617.0125,1617.2344,1617.2468,1617.4812,1617.5032,1617.7281,1617.75,1617.9844,1617.9968,1617.9968,1618.0094,1618.2312,1618.2532,1618.4781,1618.5,1618.7344,1618.7468,1618.9812,1619.0032,1619.0032,1619.0156,1619.2281,1619.25,1619.4844,1619.4968,1619.7312,1619.7532,1619.9781,1620.0,1620.0,1620.0125,1620.2344,1620.2468,1620.4812,1620.5032,1620.7281,1620.75,1620.9844,1620.9968,1620.9968,1621.0094,1621.2312,1621.2532,1621.4781,1621.5,1621.7344,1621.7468,1621.9812,1622.0032,1622.0032,1622.0156,1622.2281,1622.25,1622.4844,1622.4968,1622.7312,1622.7532,1622.9781,1623.0,1623.0,1623.0125,1623.2344,1623.2468,1623.4812,1623.5032,1623.7281,1623.75,1623.9844,1623.9968,1623.9968,1624.0094,1624.2312,1624.2532,1624.4781,1624.5,1624.7344,1624.7468,1624.9812,1625.0032,1625.0032,1625.0156,1625.2281,1625.25,1625.4844,1625.4968,1625.7312,1625.7532,1625.9781,1626.0,1628.8469,1635.0,1635.3531,1635.375,1635.7281,1635.75,1636.1031,1636.125,1636.4781,1636.5,1636.8531,1636.875,1637.2281,1637.25,1637.6031,1637.625,1637.9781,1638.0,1638.0,1638.0,1638.0,1638.0,1643.9875,1643.9875,1643.9875,1643.9875,1643.9875,1644.0,1644.0,1649.6969,1649.6969,1653.0,1653.0,1653.0,1655.8469,1655.8469,1655.8469,1656.0,1656.0,1656.0,1658.8469,1658.8469,1658.8469,1662.0,1662.0,1662.0,1664.8469,1664.8469,1664.8469,1665.0,1665.0,1665.0,1667.8469,1667.8469,1667.8469,1671.0,1671.0,1671.0,1673.8469,1673.8469,1673.8469,1674.0,1674.0,1674.0,1676.8469,1676.8469,1676.8469,1680.0,1680.0,1680.0,1682.8469,1682.8469,1682.8469,1683.0,1683.0,1683.0,1685.8469,1685.8469,1685.8469,1689.0,1689.0,1689.0,1691.8469,1691.8469,1691.8469,1692.0,1692.0,1692.0,1694.8469,1694.8469,1694.8469,1698.0,1698.0,1698.0,1700.8469,1700.8469,1700.8469,1701.0,1701.0,1701.0,1703.8469,1703.8469,1703.8469,1707.0,1707.0,1707.0,1709.8469,1709.8469,1709.8469,1710.0,1710.0,1710.0,1712.8469,1712.8469,1712.8469,1716.0,1716.0,1716.0,1718.8469,1718.8469,1718.8469,1719.0,1719.0,1719.0,1721.8469,1721.8469,1721.8469,1722.0,1722.0719,1722.0719,1722.1406,1722.1531,1722.2219,1722.2344,1724.8469,1725.0,1725.0,1725.7375,1725.7375,1725.75,1725.75,1726.4875,1726.4875,1726.5,1726.5,1727.2031,1727.2031,1727.25,1727.25,1727.9531,1727.9531,1728.0,1728.0,1728.7031,1728.7031,1728.75,1728.75,1729.4531,1729.4531,1729.5,1729.5,1730.2031,1730.2031,1730.25,1730.25,1730.9531,1730.9531,1731.0,1731.0,1731.7031,1731.7031,1731.75,1731.75,1732.4531,1732.4531,1732.5,1732.5,1733.2031,1733.2031,1733.25,1733.25,1733.9531,1733.9531,1734.0,1734.0,1734.7031,1734.7031,1734.75,1734.75,1735.4531,1735.4531,1735.5,1735.5,1736.2031,1736.2031,1736.25,1736.25,1736.9531,1736.9531,1737.0,1737.0,1737.7031,1737.7031,1737.75,1737.75,1738.4531,1738.4531,1738.5,1738.5,1739.2031,1739.2031,1739.25,1739.25,1739.9531,1739.9531,1740.0,1740.0,1740.7031,1740.7031,1740.75,1740.75,1741.4531,1741.4531,1741.5,1741.5,1742.2031,1742.2031,1742.25,1742.25,1742.9531,1742.9531,1743.0,1743.0,1743.7031,1743.7031,1743.75,1743.75,1744.4531,1744.4531,1744.5,1744.5,1745.2031,1745.2031,1745.25,1745.25,1745.9531,1745.9531,1746.0,1746.0,1746.7031,1746.7031,1746.75,1746.75,1747.4531,1747.4531,1747.5,1747.5,1748.2031,1748.2031,1748.25,1748.25,1748.9531,1748.9531,1749.0,1749.0,1749.7031,1749.7031,1749.75,1749.75,1750.4531,1750.4531,1750.5,1750.5,1751.2031,1751.2031,1751.25,1751.25,1751.9531,1751.9531,1752.0,1752.0,1752.7031,1752.7031,1752.75,1752.75,1753.4531,1753.4531,1753.5,1753.5,1754.2031,1754.2031,1754.25,1754.25,1754.9531,1754.9531,1755.0,1755.0,1755.7031,1755.7031,1755.75,1755.75,1756.4531,1756.4531,1756.5,1756.5,1757.2031,1757.2031,1757.25,1757.25,1757.9531,1757.9531,1758.0,1758.0,1758.7031,1758.7031,1758.75,1758.75,1759.4531,1759.4531,1759.5,1759.5,1760.2031,1760.2031,1760.25,1760.25,1760.9531,1760.9531,1761.0,1761.0,1761.7031,1761.7031,1761.75,1762.4531,1762.5,1762.5,1763.2031,1763.2031,1763.25,1763.9531,1764.0,1765.4187,1765.5,1766.9187,1767.0,1767.0,1767.7031,1767.75,1768.4187,1768.4531,1768.5,1768.5,1769.2031,1769.25,1769.9187,1769.9531,1770.0,1770.0,1770.7031,1770.75,1771.4187,1771.4531,1771.5,1771.5,1772.2031,1772.25,1772.9187,1772.9531,1773.0,1773.0,1773.7031,1773.75,1774.4187,1774.4531,1774.5,1774.5,1775.2031,1775.25,1775.9187,1775.9531,1776.0,1776.0,1776.7031,1776.75,1777.4187,1777.4531,1777.5,1777.5,1778.2031,1778.25,1778.9187,1778.9531,1779.0,1779.0,1779.7031,1779.75,1780.4187,1780.4531,1780.5,1780.5,1781.2031,1781.25,1781.9187,1781.9531,1782.0,1782.0,1782.7031,1782.75,1783.4187,1783.4531,1783.5,1783.5,1784.2031,1784.25,1784.9187,1784.9531,1785.0,1785.0,1785.7031,1785.75,1786.4187,1786.4531,1786.5,1786.5,1787.2031,1787.25,1787.9187,1787.9531,1788.0,1788.0,1788.7031,1788.75,1789.4187,1789.4531,1789.5,1789.5,1790.2031,1790.25,1790.9187,1790.9531,1791.0,1791.0,1791.7031,1791.75,1792.4187,1792.4531,1792.5,1792.5,1793.2031,1793.25,1793.9187,1793.9531,1794.0,1794.0,1794.7031,1794.75,1795.4187,1795.4531,1795.5,1795.5,1796.2031,1796.25,1796.9187,1796.9531,1797.0,1797.0,1797.7031,1797.75,1798.4187,1798.4531,1798.5,1798.5,1799.2031,1799.25,1799.9187,1799.9531,1800.0,1800.0,1800.7031,1800.75,1801.4187,1801.4531,1801.5,1801.5,1802.2031,1802.25,1802.9187,1802.9531,1803.0,1803.0,1803.7031,1803.75,1804.4187,1804.4531,1804.5,1804.5,1805.2031,1805.25,1805.9187,1805.9531,1806.0,1806.0,1806.7031,1806.75,1807.4187,1807.4531,1807.5,1807.5,1808.2031,1808.25,1808.9187,1808.9531,1809.0,1809.0,1809.7031,1809.75,1810.4187,1810.4531,1810.5,1810.5,1811.2031,1811.25,1811.9187,1811.9531,1812.0,1812.0,1812.7031,1812.75,1813.4187,1813.4531,1813.5,1813.5,1814.2031,1814.25,1814.9187,1814.9531,1815.0,1815.0,1815.7031,1815.75,1816.4187,1816.4531,1816.5,1816.5,1817.2031,1817.25,1817.9187,1817.9531,1818.0,1818.0,1818.7031,1818.75,1819.4187,1819.4531,1819.5,1819.5,1820.2031,1820.25,1820.9187,1820.9531,1821.0,1821.0,1821.7031,1821.75,1822.4187,1822.4531,1822.5,1822.5,1823.2031,1823.25,1823.9187,1823.9531,1824.0,1824.0,1824.7031,1824.75,1825.4187,1825.4531,1825.5,1825.5,1826.2031,1826.25,1826.9187,1826.9531,1827.0,1827.0,1827.7031,1827.75,1828.4187,1828.4531,1828.5,1828.5,1829.2031,1829.25,1829.9187,1829.9531,1830.0,1830.0,1830.0,1830.0,1835.6969,1835.6969,1835.6969,1835.6969,1836.0,1836.7031,1836.75,1837.4531,1837.5,1838.2031,1838.25,1838.9531,1839.0,1839.7031,1839.75,1840.4531,1840.5,1841.2031,1841.25,1841.9531,1842.0,1842.7031,1842.75,1843.4531,1843.5,1844.2031,1844.25,1844.9531,1845.0,1845.7031,1845.75,1846.4531,1846.5,1847.2031,1847.25,1847.9531,1848.0,1848.0,1859.3906,1859.3906];
OnOff[1]=[1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,1,0,1,0,1,0,1,0,1,0,1,0,0,1,1,0,1,0,1,0,1,0,1,0,1,0,0,1,1,0,1,0,1,0,1,0,1,0,1,0,0,1,1,0,1,0,1,0,1,0,1,0,1,0,0,1,1,0,1,0,1,0,1,0,1,0,1,0,0,1,1,0,1,0,1,0,1,0,1,0,1,0,0,1,1,0,1,0,1,0,1,0,1,0,1,0,0,1,1,0,1,0,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,0,1,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,0,0,0,1,1,1,0,0,0,1,1,1,1,0,0,0,0,1,1,1,0,0,0,1,1,1,0,0,0,1,1,1,1,0,0,0,0,1,1,1,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,1,0,0,0,0,0,1,1,1,1,0,0,0,0,1,1,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,1,1,1,0,0,0,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0,1,1,0,0,1,0,1,0,1,0
