mouth-animation, get keyframes form precomp (with framesToTime) without playing other states
COW Forums : Adobe After Effects Expressions
Georg Hübler
on May 22, 2017 at 11:14:04 am
Hello there,
i am animating a character. In a pre-comp i set 10 different mouthpositions every 25th frame. There are many pixelbased layers from Photoshop which i transformed with puppetpins into every single position (like "O", "AH", laughing, etc.).
In the main composition i enabled timeremapping at this pre-comp and gave it a slidereffect.
mouth=effect("Slider Control")("Slider")
framesToTime(mouth*25)
So i am able to jump to every single mouthposition in the precomp.
But when i want to interpolate from position 1 to position 4 in my precomp it also animates position 2 and 3, for sure.
When i use hold frames it directly jumps to the wanted frame, but then i am missing the linear interpolation and the animation.
So i am searching for a possibility to interpolate from 1 to 4 by skipping position 2 and 3.
Any ideas.
Georg from Leipzig/Germany
Mundbewegung=effect("Slider Control")("Slider")
framesToTime(Mundbewegung*25)
Steve Sierra
Re: mouth-animation, get keyframes form precomp (with framesToTime) without playing other states
on May 22, 2017 at 2:40:16 pm
I think you should check this out :
http://www.motionscript.com/design-guide/marker-sync.html
Georg Hübler
on May 22, 2017 at 5:09:04 pm
Hi Steve,
thanks for your help. This seemed very interesting, so I tried to copy this to my project.
It worked so far, but it is unfortunately not exactly the thing I need.
thanks.
Dan Ebberts
on May 22, 2017 at 7:12:49 pm
You won't be able to create tweening that doesn't already exist using time remapping. You could develop expressions for each of your Puppet pins that could tween from one position to another. The details would depend on how you have things set up, but seems very do-able.
Dan
