Out of range error with layer index
COW Forums : Adobe After Effects Expressions
Eva Lepik
on May 15, 2017 at 8:24:25 am
Hey,
I am trying to link camera's focus distance to a chosen layer.
The layer can be chosen (and keyframed) with a slider.
I have also added a Math.round expression to controller slider.
But the expression below gives Out of range error, and I can't understand why.
Could anybody show me where the mistake is?
Eva
n = thisComp.layer("CONTROLS").effect("Focus on layer")("Slider"); // Math.round expression is added to slider
Z = thisComp.layer(n).transform.position[2];
Z-(thisComp.layer("Cam control").transform.position[2])
Steve Sierra
Re: Out of range error with layer index
on May 15, 2017 at 9:20:51 am
You can't have n = 0, since it is used as the layer index in Z (indexes start at 1).
What happens when your ("Focus on Layer") slider hits 0 ?
I think you should do an if/else statement to set a default value to your focal distance when the slider is at 0.
Hope this helps 😉
Cheers !
Eva Lepik
on May 15, 2017 at 9:42:56 am
Hi Steve,
Thanks for the reply.
I put this expression to slider to avoid it hits 0, and this seems to work ok (below).
That's why I don't understand the reason it gives me 'out of range' error.
Right now the slider value is 6, and still the error is there.
Regards,
Math.round(clamp(value, min=5, max=thisComp.numLayers));
Steve Sierra
on May 15, 2017 at 10:53:57 am
Hi again,
Try putting your clamp in your n variable...
n = clamp(thisComp.layer("CONTROLS").effect("Focus on layer")("Slider"), 5, thisComp.numLayers);
Cheers !
Eva Lepik
on May 16, 2017 at 7:37:52 am
Hi again Steve,
Thanks for the advice, that helped!
But as the resulted animation hold the focus distance until next keyframe (clamped, or maybe this is a wrong word), after trial and error I came up with the expression below:
This works, also if there are no keyframes on the layer index slider.
I'm pretty sure it could be shorter or written in a better form, but it seams to hold the focus on the layer on all cases ☺
Maybe that's useful for someone else, too.
Regards,
Eva
x = thisComp.layer(2).effect("Focus on layer")("Slider");
n = 0;
try {
if (x.numKeys > 0) { // if there are keyframes
n = x.nearestKey(time).index;
if (x.key(n).time > time) n--;
if (n > 0 && x.numKeys >= n+1 ) { // if there is 1 more keyframe after current keyframe
t = time;
tMin = x.key(n).time;
tMax = x.key(n+1).time;
y1 = x.key(n).value;
y2 = x.key(n+1).value;
z1 = thisComp.layer(y1).position[2];
z2 = thisComp.layer(y2).position[2];
CamPos1 = thisComp.layer("Cam control").position.valueAtTime(tMin)[2];
CamPos2 = thisComp.layer("Cam control").position.valueAtTime(tMax)[2];
value1 = z1-(CamPos1); // Z position of layer 1 - Z position of cam
value2 = z2-(CamPos2); // Z position of layer 2 - Z position of cam
ease(t, tMin, tMax, value1, value2);
else if (n > 0 && x.numKeys = n ) { // if this is the last keyframe
CamPos = thisComp.layer("Cam control").position[2];
cameraOption.focusDistance = z1 - CamPos;
else {
x = Math.round(clamp (thisComp.layer(2).effect("Focus on layer")("Slider"), 5, thisComp.numLayers));
L = thisComp.layer(x).position[2];
L - CamPos
catch (e) {
