Shape layer hierarchy confused
COW Forums : Adobe After Effects Expressions
Ilya Sire
on Apr 27, 2017 at 8:37:33 am
Hello, I have a question about shape layer hierarchy expression as here
how to get opacity from Group 2> Rectangle 1> Opactity?
Please help me
Thank you
thisProperty.propertyGroup(3)(1).transform.opacity
Xavier Gomez
Re: Shape layer hierarchy confused
on Apr 27, 2017 at 12:55:34 pm
Maybe this:
thisProperty.propertyGroup(6).content("Group 2").content("Rectangle 1").transform.opacity;
or :
thisLayer.content("Group 2").content("Rectangle 1").transform.opacity;
Xavier
thisProperty.propertyGroup(5)("Group 2").content("Rectangle 1").transform.opacity; would also work, but less clear imo.
Ilya Sire
on Apr 27, 2017 at 2:57:05 pm
Yes it worked, but could you please explain me why propertyGroup(6)? How did you count it?
I dont really understand about shape indexing.
Xavier Gomez
on Apr 27, 2017 at 4:05:23 pm
In :
you "get down 6 times" to go from the Layer to the Opacity.
(Layer --> Contents ---> "Group 2" ---> Contents ----> Rectangle 1 ----> Transform ---> Opacity
Hence, the other way round, you need to climb up 6 times to go from the Opacity to the Layer.
One thing to know is that every Shape Group inside a shape layer has a "Contents" and a "Transform"
(similarly to the layer itself having a Contents and a Transform)
The "Contents" step is hidden in the UI though, but it is still there somehow and must be accounted for.
Xavier
Ilya Sire
on Apr 27, 2017 at 4:39:23 pm
oh i see it. Thank you for your explanation.
so i learned this way;
1) counting from thisLayer down to property, be like:
thisLayer.content(2).content(1).transform.opacity;
2) counting from thisProperty climb up to other group, will be like:
thisProperty.propertyGroup(6).content(2).content(1).transform.opacity;
i guess level 6 = thisLayer is maximum
Kyle Daily
on Apr 27, 2017 at 2:02:51 pm
You can always pick whip the property to get its syntax.
thisComp.layer("Shape study").content("Group 2").content("Rectangle 1").transform.opacity
Ilya Sire
on Apr 28, 2017 at 4:12:36 am
Thank you for this lesson. :)
