rd_Slated to work with precomps/nested comps
COW Forums : Adobe After Effects Expressions
Avinash Ramanath
on Apr 24, 2017 at 5:54:30 pm
Can you please make the popular rd_Slated script to look for text and videos inside pre comps. It will be a life saver. Pasting the full code here
// rd_Slated.jsx
// Copyright (c) 2008-2013 Jeffrey R. Almasol. All rights reserved.
// portfolio: http://www.redefinery.com
// Name: rd_Slated
// Version: 1.2
// Description:
// This script renders slates, single-frame images of a specific template composition
// whose data is fed by the information in a text file exported from a spreadsheet.
// Prerequisites:
// -- This script requires After Effects CS4 or later.
// Usage:
// 1. Run this script.
// 2. Select the project containing the template composition named "comp"
// to use for the slates.
// 3. Select the tab-delimited data file whose columnar data values match
// the layer names in the "comp" template.
// 4. Select the output folder into which the slates will be rendered.
// The slates will be rendered in Photoshop format.
// Notes:
// -- The machine on which you run the script should have an output module
// template named "Photoshop", which should be available in the default set
// of templates.
// Legal Notices:
// This script is provided "as is," without warranty of any kind, expressed or implied.
// In no event shall the script's author be held liable for any damages arising in any
// way from the use of this script.
// This script is excerpted from Adobe After Effects CC Visual Effects and Compositing Studio Techniques by Mark Christiansen.
// (c) 2013. Published by Adobe Press. All rights reserved. A complete chapter on scripting
// by Jeff Almasol is included with the book. Additional scripts are available at
// http://aescripts.com/rd-studio-techniques/
(function rd_Slated()
// Globals
// Store all constants in a global object, for consolidated organization in ExtendScript Toolkit's Data Browser
var rd_SlatedData = new Object();
rd_SlatedData.scriptName = "rd: Slated";
rd_SlatedData.scriptTitle = rd_SlatedData.scriptName + " v1.2";
// Various text strings are defined as associative arrays (dictionaries) to support localizability via rd_localize() function
rd_SlatedData.strTplCompName = {en: "template"};
rd_SlatedData.strSelTplProj = {en: "Select the template project"};
rd_SlatedData.strSelDataFile = {en: "Select the text file containing slate data"};
rd_SlatedData.strSelOutFolder = {en: "Select the output folder for rendered slates"};
rd_SlatedData.strSlatesFolderSuffix = {en: " Slates"};
rd_SlatedData.strErrOpenProj = {en: "Could not open the template project."};
rd_SlatedData.strErrNoTplComp = {en: "Could not find a comp named 'template'."};
rd_SlatedData.strErrCreateOutFolder = {en: "Could not create the output folder."};
rd_SlatedData.strMinAE90 = {en: "This script requires Adobe After Effects CS4 or later."};
// rd_localize()
// Description:
// This function localizes the given string variable based on the current locale.
// Parameters:
// strVar - The string variable's name.
// Returns:
// String.
function rd_localize(strVar)
return strVar["en"];
// rd_Slated_main()
// Description:
// This function performs the main operation of the script.
// Parameters:
// None.
// Returns:
// Nothing.
function rd_Slated_main()
// Select/open the template project
var projFile = File.openDialog(rd_localize(rd_SlatedData.strSelTplProj));
if ((projFile === null) || !projFile.exists)
return;
var proj = app.open(projFile);
if (proj === null)
return;
// Check that the template comp exists
var comp = null;
for (var i=1; i&lt;=proj.numItems; i++)
if ((proj.item(i) instanceof CompItem) && (proj.item(i).name === rd_localize(rd_SlatedData.strTplCompName)))
comp = proj.item(i);
break;
// If comp is still null, the comp doesn't exist in the project
if (comp === null)
alert(rd_localize(rd_SlatedData.strErrNoTplComp), rd_SlatedData.scriptName);
return;
// Select the data file
var dataFile = File.openDialog(rd_localize(rd_SlatedData.strSelDataFile));
if ((dataFile === null) || !dataFile.exists)
return;
// Select the folder where the slates will be rendered
var outFolder = Folder.selectDialog(rd_localize(rd_SlatedData.strSelOutFolder));
if (outFolder === null)
return;
// If the folder doesn't exist, create it
if (!outFolder.exists)
if (!outFolder.create())
alert(rd_localize(rd_SlatedData.strErrCreateOutFolder), rd_SlatedData.scriptName);
return;
// Build a catalog of layer names for text and footage layers, the types of layers that can be replaced
var layerCat = new Array();
for (var i=1; i&lt;=comp.numLayers; i++)
// Look for text (TextLayer) and footage (AVLayer) layers only
var layer = comp.layer(i);
if ((layer instanceof TextLayer) || (layer instanceof AVLayer))
var layerName = layer.name;
// Check if the layer's name was previously stored; this allows multiple layers
// to be updated
if (layerCat[layerName] === undefined)
// Layer name wasn't previously encountered, so create a new array to store layer indices
layerCat[layerName] = new Array();
// Append the current layer's index to the newly created or existing (if same layer name was previously encountered)
layerCat[layerName].push(i);
// Create a subfolder to place the slate comps and any footage needed for each
// Subfolder name will be based on the data file name
var slatesFolder = app.project.items.addFolder(dataFile.name + rd_localize(rd_SlatedData.strSlatesFolderSuffix));
// Process the lines of text from the data file
// First line should be the field names, tab-separated, with subsequent lines the data
// Open the data file for reading
dataFile.open("r");
// Read the first line, which are the field names
var fields = dataFile.readln();
if (!dataFile.eof)
// Split the field string at tab characters
var fieldNames = fields.split("\t");
// Read the rest of the lines, and create slate comps for each
var dataLine, dataValues, layersToUpdate, layerData, currLayer;
while (!dataFile.eof)
dataLine = dataFile.readln();
dataValues = dataLine.split("\t");
// Make sure the data line contains the same number of values as there are fields
if (dataValues.length !== fieldNames.length)
continue;
// Duplicate the comp for the current line of data, and move it into the slates folder
var slateComp = comp.duplicate();
slateComp.parentFolder = slatesFolder;
// Name the comp based on the first field's value (hopefully, it's unique)
if (fieldNames.length > 0)
slateComp.name = dataValues[0];
// Loop through the fields and match up the data to the layers
for (var f=0; f<fieldNames.length; f++)
// Get the set of layers matching the current field's name
layersToUpdate = layerCat[fieldNames[f]];
// Get the data to use for the field
layerData = dataValues[f];
// Loop through all matching layers, and update their content using the data to use
for (var l=1; l<layersToUpdate.length; l++)
currLayer = slateComp.layer(layersToUpdate[l]);
// Depending on the layer type, update as appropriate
if (currLayer instanceof TextLayer)
// For a text layer, use the data value as the source text
currLayer.sourceText.setValue(new TextDocument(layerData));
else if (currLayer instanceof AVLayer)
// For a footage layer, import the data value (hopefully is the footage's file name) and replace the source for the layer
if (File(layerData).exists)
var fItem = proj.importFile(new ImportOptions(File(layerData)));
if (fItem !== null)
// Move footage to the slates folder, then replace the footage layer
fItem.parentFolder = slatesFolder;
currLayer.replaceSource(fItem, false);
// Trim the comp to the first frame of the work area
slateComp.workAreaDuration = slateComp.frameDuration;
// Add the comp to the render queue; use Photoshop output module template
var rqItem = proj.renderQueue.items.add(slateComp);
rqItem.outputModule(1).applyTemplate("Photoshop");
rqItem.outputModule(1).file = new File(outFolder.fsName + "/" + slateComp.name + "_[#####].psd");
// Close the data file when done
dataFile.close();
// Start the render
proj.renderQueue.render();
// Select only the slates folder
proj.item(i).selected = false;
slatesFolder.selected = true;
// main code:
// Prerequisite check for After Effects CS4 or later
if (parseFloat(app.version) &lt; 9.0)
alert(rd_localize(rd_SlatedData.strMinAE90), rd_SlatedData.scriptName);
else
rd_Slated_main();
