Access string without quotes
COW Forums : Adobe After Effects Expressions
Steve Sierra
on Apr 14, 2017 at 5:08:13 am
I need to get a comp name and put it in an expression via scripting.
The problem is that the comp name seems to be given with double quotes, and, as far as I know, expressions via scripting require simple quotes...
I can work around the problem by renaming the comp, but I'd prefer leaving it as is, in case it is referenced in another expression.
I tried changing the name for my script then re-changing it back at the end + applying autoFixExpressions, but it didn't work.
Thanks !;)
Dan Ebberts
Re: Access string without quotes
on Apr 14, 2017 at 6:47:17 am
If you want to include double quotes in the expression, you can wrap the expression in single quotes in the script. For example:
var myExpr = 'comp("Comp 1").layer("Layer 1").transform.position';
Dan
Steve Sierra
on Apr 14, 2017 at 8:20:27 am
Great !
Thanks again Dan ;)
