360/ Expression + Expression pick whip not working
COW Forums : Adobe After Effects Expressions
Valentijn Wisseborn
on Mar 22, 2017 at 9:27:29 am
Hello,
im trying to make this really simple accent 'explosion', but the thing is
that i get an error when im trying to use the expression:
360/content("Repeater 1").copies
I am probably a huge retard, but i honestly do not know why it isnt working
error log:
Expression disabled. Error at line 0 in property 'position of layer 1 ('Shape layer 1') in comp 'Intro'
Expression result must be of dimension 2, not 1.
Thanks for helping me out =]
Dan Ebberts
Re: 360/ Expression + Expression pick whip not working
on Mar 22, 2017 at 5:33:09 pm
It looks like applied the expression to a Position property, which is expecting a array, like [x,y] and you've supplied a single number. What's the effect you're going for? You could do something like this:
{360/content("Repeater 1").copies,value[1]]
but that will only affect the x axis.
Dan
Valentijn Wisseborn
on Mar 23, 2017 at 9:35:40 am
I am trying to set the copies from the repeater in a circle,
you need to know that I have been After effects for around a week now;
and i've learned doing this in a tutorial, at least: it isnt working
it might help providing a link to the video:
trying to make something like that
btw: thanks for helping me out =]
Valentijn Wisseborn
on Mar 23, 2017 at 9:38:40 am
The expression at 5:45
Dan Ebberts
on Mar 23, 2017 at 11:18:19 am
The tutorial shows the expression being applied to the Rotation property, which is a 1D property, which should work fine with that expression.
The error message you posted indicates that you applied the expression to the Position property, which is expecting a 2D value, so that expression won't work there.
Dan
