Random start position to fixed end position, but with fluid curve motion and rotation
COW Forums : Adobe After Effects Expressions
Chris Harston
on Mar 17, 2017 at 10:58:17 am
Hi
Very new to expressions and have only really managed to work out the basics. However, I am hoping this incredible website of wisdom and knowledge can help me out.
I have multiple solids that when all in their fixed end positions form the shape of an object.
What I am in need of is an expression that I can copy across all of these that makes them start in a random position (within a set area of my comp), and then fall into final position. So far I have managed to find this
moveDur = 2;
seedRandom(index,true);
startPos = random([0-2000,0-800]);
easeIn(time,inPoint,inPoint+moveDur,startPos,value)
This gives a linear movement over 2 seconds. However (I might be asking for quite a lot), I also need them to rotate and fall in a curved arc (relative to their random start position and their final end position). Hopefully I am describing this well enough.
So, in short- this.
If this doesn't make sense, or I can elaborate further please do ask as I am really interested in how to combine all this.
Many thanks
Chris
Chris Harston
Re: Random start position to fixed end position, but with fluid curve motion and rotation
on Mar 17, 2017 at 2:01:36 pm
I also want them to come in sequentially. If that is even possible.
So each is like a brick slowly building up an object.
I'm starting to think I may need to keyframe each one individually.
Dan Ebberts
on Mar 17, 2017 at 4:22:42 pm
Play around with this:
moveDur = 2;
delay = .1;
startPos = value + random([-2000,-800],[0,800]);
tStart = inPoint+delay*(index-1);
tEnd = tStart + moveDur;
y = easeOut(time,tStart,tEnd,startPos[1],value[1]);
x = easeIn(time,tStart,tEnd,startPos[0],value[0]);
[x,y]
Dan
Chris Harston
on Mar 21, 2017 at 12:04:42 pm
Brilliant, thank you very much! I'll have a play and see what I get.
Thanks again
Chris
