Animate opacity using data in text file
COW Forums : Adobe After Effects Expressions
mike driz
on Feb 3, 2017 at 1:36:35 am
I'm trying to write a simple expression to animate the opacity (on/off) of a solid
according to data in a text file. The text file simply contains one line for each frame and will
specify if solid should be on/off.
Can anyone help me out? thanks for any help you could give.
Emre Anil
Re: Animate opacity using data in text file
on Feb 3, 2017 at 11:15:18 am
Why don't you just copy the variables to a text layer and use that layer's sourceText for your expression?
mike driz
on Feb 3, 2017 at 12:38:22 pm
Can you give me any insight on writing that expression?
Either way, thanks for replying! :)
Emre Anil
on Feb 3, 2017 at 1:45:43 pm
Here's an example:
Pick-whip your solid layer's opacity to the text layer's Source Text property to change *thisComp.layer("source").text.sourceText*
values = thisComp.layer("source").text.sourceText.split("\r");
f = timeToFrames(time);
if( f < values.length)
values[f];
else
0;
mike driz
on Feb 3, 2017 at 3:10:29 pm
Emre, thanks for much for your help! I got it to work.
It is much appreciated!
Have a great day :)
