color sample size/possition
COW Forums : Adobe After Effects Expressions
Vojtěch Palme
on Jan 10, 2017 at 7:15:42 pm
Greetings, I want to make an interactive background consisting of a grid of square, animated PreComps animating away as something passes over them.
To do that I've decided to make a matte and measure lightness under each of the squares and with the value it gives me remap its time.
My comp is divided to 9x5 squers 220x220px each.
To measure their lightness I use 45 slider controllers with this expression:
sampleSize = [220,220];
target = thisComp.layer("matte");
samplePos = [0,0];
rgb = target.sampleImage(samplePos, sampleSize, true, time);
hsl = rgbToHsl(rgb);
hsl[2]*100
samplePos = [220,0];
hsl[2]*100
etc.. moving the samplePos always by value of 220.
Then I link each of the square's time remap value to corresponding slider.
It kind of works except I'm getting some kind of overlap of the measured areas.
(on the left is the result - all the cyrcles that are under the matte (on the right) should be gone, but they only animate half way)
How should I properly define the grid? And is there an easier way to achive my goal?
Thank you.
Dan Ebberts
Re: color sample size/possition
on Jan 10, 2017 at 8:41:34 pm
It seems like it should be like this:
sampleSize = [110,110];
samplePos = [110,110];
samplePos = [330,110];
etc.
Dan
Vojtěch Palme
on Jan 11, 2017 at 12:42:22 pm
Works like a charm. As always thank you oh grand expressions wizard Dan :)
