Have the scale change between two states dependent on if the audio amplitude is over a certain value.
COW Forums : Adobe After Effects Expressions
Ben Emmons
on Jan 3, 2017 at 3:01:10 pm
Hi guys,
I'm having a little trouble in getting an expression to work.
What I need to do is have the scale of my 'Clouds' change to 250% if the audio amplitude is over 25 and if the audio amplitude is under 25, change to 216%. I've tried lots of different solutions, however I am brand new to expressions and would love some help :).
Dan Ebberts
Re: Have the scale change between two states dependent on if the audio amplitude is over a certain value.
on Jan 3, 2017 at 5:26:47 pm
Assuming you have converted the audio to keyframes, something like this maybe:
a = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
s = a > 25 ? 250 : 216;
[s,s]
Dan
Ben Emmons
on Jan 3, 2017 at 5:29:07 pm
Perfect!
Thanks for the help Dan :)
