Pulse expression edit
COW Forums : Adobe After Effects Expressions
Mario Pascal
on Dec 28, 2016 at 5:49:37 pm
I need an edit on this expression
minAudio = 0;
maxAudio = 100;
minStretch = 90;
maxStretch = 130;
audioLev = thisComp.layer("Sound Keys").effect("Sound Keys")("Output 1");
s = linear(audioLev, minAudio, maxAudio, minStretch, maxStretch);
[s,s]
Instead of it stretching I want it to control the opacity so when the audio level is 100 the opacity will be 130 as the max. Yes, I used Sound Keys to isolate bass so it will react to bass, help please!
Dan Ebberts
Re: Pulse expression edit
on Dec 28, 2016 at 6:39:36 pm
I'm not sure why you would want opacity to go to 130, but editing the expression should be pretty easy. All you need to do is remove the last line:
minAudio = 0;
maxAudio = 100;
minStretch = 90;
maxStretch = 130;
Dan
Mario Pascal
on Dec 28, 2016 at 7:07:37 pm
Lol thanks but i meant like if the audio goes to 100 then the opacity will go to x%(whatever number i choose)
Dan Ebberts
on Dec 28, 2016 at 7:49:05 pm
Then I say choose one and set maxStretch accordingly. 😉
Dan
May Kum
on Jan 27, 2017 at 12:13:41 pm
Thanks, Dan! Would you tell me what does "s" means in this expression?
Dan Ebberts
on Jan 27, 2017 at 4:51:13 pm
It's just a variable name. I could have used anything. The purpose of the variable is to temporarily store the value of the linear() interpolation so I can use it in the next line so that the scale will be the same for x and y.
Dan
