Problem with the order of actions. how to create a slider without losing the original property selection array
COW Forums : Adobe After Effects Expressions
Tal Arbiv
on Dec 12, 2016 at 12:33:51 am
I've got a double 'for' loop creating expressions on a selected properties of selected layers. the expression contains reference to a slider that is created on current layer within the same loop.
problem is, if i place the slider creation after the expression assignment, the non existing reference breaks the loop,
and if i place it after, my guess is that it replaces the active selection of the original property with the newly created slider and that messes up the rest of the loop .
result 1 : faulty expression
result 2 : expression assignment skipped
// (1) :
expr = "effect('name')('slider') //+something+something.... ;
for (i=0; i <= sellayers.length-1; i++){
for (p=0; p <= selprop.length-1; p++){
selprop[p].expression = expr;
ofset = sellayers[i].Effects.addProperty("ADBE Slider Control");
ofset.name = "name";
ofset.property("Slider").setValue(0);
// (2) :
Big thank you in advance
// (1) :
for (i=0; i &lt;= sellayers.length-1; i++){
for (p=0; p &lt;= selprop.length-1; p++){
// (2) :
