Issues with if/else command.
COW Forums : Adobe After Effects Expressions
David Jouppi
on Dec 7, 2016 at 9:42:42 pm
Hey there!
Im running into a problem with an "if else" command. I have around 100 objects in a comp that I'm trying to assign a random rotation speeds to. I want them to either rotate to the left or the right. Additionally, regardless of which direction they're rotating, I want them to stay within a speed range, so that I can avoid having any of them standing totally still, or moving wayyyy to fast. I wrote out the following experession, which I figured should work, however, they always end up rotating in the same direction. Anyone know whats going on? I deduced the problem is happening at the the 3rd line. I cant get variable "drctn," to result in anything besides the value: -1. I assume I'm using the "if else" command incorrectly.
seedRandom(index,true);
rndmA = Math.round(random(1,2));
if ( rndmA = 1 ) [drctn=-1] else [drctn=1];
animSpd = random(20,60);
time * (animSpd*drctn)
Dan Ebberts
Re: Issues with if/else command.
on Dec 7, 2016 at 10:27:27 pm
I think you just need to change:
( rndmA = 1 )
to:
( rndmA == 1 )
Dan
David Jouppi
on Dec 7, 2016 at 10:38:06 pm
That worked! Thanks so much, Dan! I don't know what everyone would do without your expertise!
