Shape layer property customization via ExtendScript
COW Forums : Adobe After Effects Expressions
Krishna Moorthy
on Nov 8, 2016 at 1:02:55 pm
Hi, I have to access the size position and roundness values of a shape layer so that I can change those values to the ones I desire.
The code snippet I tries is:
var shapeLayer = pipComp.layers.addShape(); // adding a shape layer to the pipComp
var contents = shapeLayer.property("ADBE Root Vectors Group"); // Accessing the contents of the shape layer
var shapeRect = contents.addProperty("ADBE Vector Shape - Rect"); // Adding a rectangle to the shape layer
var shapeFill = contents.addProperty("ADBE Vector Graphic - Fill");
var rectSize = shapeLayer.property("ADBE Vector Rect Size");
var rectPosition = shapeLayer.property("ADBE Vector Rect Position");
var rectRoundness = shapeLayer.property("ADBE Vector Rect Roundness");
rectSize.setValue([600, 400]);
rectPosition.setValue([0.0, -90]);
rectRoundness.setValue(10);
ESTK throws an error stating, "null is not an object" at this line
and the code terminates execution. How can I solve this to achieve what I am looking for. Kindly, Help!!
Thanks in advance,
Krishna
Dan Ebberts
Re: Shape layer property customization via ExtendScript
on Nov 8, 2016 at 1:45:52 pm
This should work:
var pipComp = app.project.activeItem;
shapeRect = contents.property("ADBE Vector Shape - Rect"); // adding fill invalidates shapeRect
var rectSize = shapeRect.property("ADBE Vector Rect Size");
var rectPosition = shapeRect.property("ADBE Vector Rect Position");
var rectRoundness = shapeRect.property("ADBE Vector Rect Roundness");
Dan
