Mask point co-ordinates
COW Forums : Adobe After Effects Expressions
Rury Nelson
on Nov 8, 2016 at 10:11:34 am
Hello, world!
I was wondering if it's possible to reference the position of a point within a mask?
Cheers,
Rury
Dan Ebberts
Re: Mask point co-ordinates
on Nov 8, 2016 at 1:33:18 pm
Unfortunately, not directly with an expression.
Dan
Rury Nelson
on Nov 9, 2016 at 11:52:56 am
In terms of memory though, are the points stored in anything like an XML or such? I suppose I don't really need active control of the points through expressions or scripts.
My plan is essentially to build a mask in After Effects and then have the ability to read and reconstruct that mask in another program. So I need to get those points to an XML format.
Dan Ebberts
on Nov 9, 2016 at 2:23:51 pm
Scripting does have access to mask path data, including vertices, inTangets, and outTangents. You could convert the path data to whatever format you like and write it to a file with a script.
Dan
Roei Tzoref
on Nov 10, 2016 at 7:44:26 am
Bao mask avenger is a script that allows you to access the mask vertices as position targets via expression. It can also create nulls for you.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues Tutorials
