Wiggle and clamp expression
COW Forums : Adobe After Effects Expressions
Lloyd Lively
on Nov 2, 2016 at 7:33:24 pm
I have a wiggle expression on the Fill 1: color of a shape layer
wiggle(3,2);
this is being used to just change the color of a Christmas light bulb. All the other colors are fine but I would rather it didn't use black or white. I'm not good enough with expressions yet to write the clamp to set the limits. Any help would be greatly appreciated. If there is a better way please let me know.
Lloyd
Lloyd Lively
Oportet Eum Occidi
Dan Ebberts
Re: Wiggle and clamp expression
on Nov 2, 2016 at 10:09:10 pm
If you set the color to mid grey, something like this should keep it from going black or white:
wiggle(3,.4)
Dan
Lloyd Lively
on Nov 3, 2016 at 1:34:20 pm
I'll try that. Much appreciated.
Lloyd Lively
Oportet Eum Occidi
joshua faget
on Nov 3, 2016 at 3:33:43 pm
This will change the Hue of the color only, not the saturation or brightness... you can adjust it manually from the AE color picker!
Speed=4;
Amount= 100; //a value between 0,100
HSL = rgbToHsl(value);
H = linear(wiggle(Speed,Amount)[0]/100,-1,1,0,1);
S=HSL[1];
L=HSL[2];
hslToRgb([H,S,L,1])
Lloyd Lively
on Nov 3, 2016 at 3:36:12 pm
Great! Thank you very much.
Lloyd Lively
Oportet Eum Occidi
