LoopOut a Mesh warp?
COW Forums : Adobe After Effects Expressions
Kurisuta vd Wilk
on Oct 24, 2016 at 5:26:05 pm
Hi!
I have a .ai layer which is part of a rig, and I would like to mesh warp this layer continuously throughout the whole comp.
So I animated the mesh warp, and I wanted to LoopOut these keyframes so the movement would be there all the time, But I get an error that this expression is not possible with this effect.
Anyone know why?
But more important, is there a work around?
It is not possible to precomp this layer and time-remap this movement since its part of a rig and linked with a lot of other expressions to other layers and comps.
Anyone having an idea I can try?
Dan Ebberts
Re: LoopOut a Mesh warp?
on Oct 24, 2016 at 6:29:36 pm
Try this:
if (numKeys >1){
if (time > key(numKeys).time){
t = (time - key(numKeys).time)%(key(numKeys).time - key(1).time);
valueAtTime(t);
}else{
value;
}else
value
Dan
Dan Ebberts
on Oct 24, 2016 at 6:31:46 pm
That wasn't quite right. This should be better:
if (numKeys >1){
valueAtTime(key(1).time + t);
}else{
value;
}else
value
Dan
Kurisuta vd Wilk
on Oct 25, 2016 at 10:25:05 am
Yes ! Works like a charm ! Thanks Dan !
