How to get shape path vertices with script?
COW Forums : Adobe After Effects Expressions
joshua faget
on Oct 16, 2016 at 1:03:26 pm
Hello,
What I am trying to do is get all the vertices points from a selected path. Is this possible?
I tried doing as described on page 177 of CS6 scripting guide, but I am getting a undefined result.
var selectedShape = app.project.activeItem.selectedProperties[0].value.vertices ;
alert(selectedShape);
Xavier Gomez
Re: How to get shape path vertices with script?
on Oct 16, 2016 at 3:54:01 pm
What property are you selecting ? Normally your code line should work if you select a mask path property or a shape path property.
It won't work for special shapes like Ellipse/Rectangle/Star (you'd need to convert them to a path before).
Xavier
joshua faget
on Oct 16, 2016 at 5:11:34 pm
I was selecting the proper thing, adding a .path fixed it!
var selectedShape = app.project.activeItem.selectedProperties[0].path.value.vertices;
Xavier Gomez
on Oct 16, 2016 at 6:00:54 pm
Ah ok...
if you select a mask path (keyframable), the mask group (renamable) is selected along, and selectedProperties[0] is the mask group, not the mask path.
Same for paths inside vector layers.
