Limit movement to Comp dimensions
COW Forums : Adobe After Effects Expressions
Andreas Woelfl
on Sep 22, 2016 at 10:25:31 am
Hello everybody,
I am trying to write a script that allows me to grab and move an element inside the comps borders, but only within the comp's width and height. So even if I would drag the element outside the comp it would stay at the border of the comp.
Please find the script that I added to the object in my comp below.
With the script that I have so far it works visual wise. So the square gets stuck on the comp border when ever I try to drag it outside the comp. The only problem I have is that it seems that if I drag the square for example 5000px to the right outside the comp it stucks directly at the border. But when I want to drag it back in the middle I have to drag it at first 5000px back to the left until I can see the square moving inside the comp.
Can anybody tell me if I need an adjustment to my code or maybe a complete other aproach?
Thanks for the help!
xPos = transform.position[0];
if (transform.position[0]>1920) {
xPos = 1920
if (transform.position[0]&lt;0) {
xPos = 0
yPos = transform.position[1];
[xPos, yPos]
Xavier Gomez
Re: Limit movement to Comp dimensions
on Sep 22, 2016 at 12:40:56 pm
An expression can bypass the value as you did, but cannot prevent you to set a given value.
I dont think there is a way to do what you want.
Note: you could shorten the expression, and make it valid for any comp size, as follows:
pos = value;
pos[0] = clamp(pos[0], 0, thisComp.width);
pos;
Xavier
Xavier Gomez
on Sep 22, 2016 at 12:47:48 pm
You could also hit P to reveal the position property of the layer, then either :
right click the position property, > reset to recenter,
or shift+scroll the x value to scroll faster.
Xavier
