Got Delay When Keyframing parenting position
COW Forums : Adobe After Effects Expressions
Natanael Alfredo
on Sep 18, 2016 at 12:13:17 am
Hi all, I'm new here.
So I want to control position from other comp using "Point Control"
I used simple parent expression like this
comp("Comp 2").layer("Comp 1").effect("Point Control")("Point")
Everything works well (Image 1)
But when I offset Comp 1 to the right side (Image 2). The changing position didn't match with the keyframe. I got couple seconds delay. So what should I do to make to make changing position exactly the same with the keyframe no matter how much I offset the comp 1.
Sorry, if my English isn't good.
Cheers :)
Dan Ebberts
Re: Got Delay When Keyframing parenting position
on Sep 18, 2016 at 3:45:14 am
Try this:
C = comp("Comp 2");
L = C.layer(thisComp.name);
ctrl = L.effect("Point Control")("Point");
ctrl.valueAtTime(time + L.startTime)
Dan
Natanael Alfredo
on Sep 18, 2016 at 4:52:16 am
Perfectly works!! Thank you so much :) :)
