Number counter with comma
COW Forums : Adobe After Effects Expressions
Adam Zygadlo
on Sep 7, 2016 at 9:48:15 am
Good morning everyone,
I wonder if anyone can help out with this issue. At present, I have built a number counter that builds up from 0 to 150k. I sent the animation to the client for review and they came back with a feedback, where they want to place a comma in the number like 34,843.
The way I built the project so far was using the text layer and link the source settings to a slide control to animate the numbers using this expression:
n = comp("LINK TO SLIDER");
d = 1;
Math.round(n*d)/d;
Is there a way to update this expression, where the numbers has the comma within the text? (23,289, 56,239, 100,000)
Thank you in advance,
Addz
d = 1;
Math.round(n*d)/d;
Adam Jozef Zygadlo
Motion Graphic Designer
07708 124 915
http://www.jarbrain.com
'Filled with brainy goodness.'
Adam Zygadlo
Re: Number counter with comma
on Sep 7, 2016 at 10:34:59 am
Alright, I spent some time browsing on this forum, find a great expressions from Dan Ebberts (https://forums.creativecow.net/readpost/227/16453) which that did the trick.
n = 0+comp("LINK TO SLIDER");
s = "" + n;
str = s.substr(-s.length, (s.length-1)%3 +1);
for (i = Math.floor((s.length-1)/3); i > 0; i--){
str += "," + s.substr(-i*3,3);
str
However, it has now caused another problem where the numbers goes all werid like '9,234,6.6,875'. Ideally, it would be great to round up the number to 91,607. :^)
Adam Jozef Zygadlo
07708 124 915
Adam Zygadlo
on Sep 7, 2016 at 11:14:57 am
Awesome, I have solved the original problem as well as the new issue when introducing new expressions.
Basically, I added another slider control between the text layer to the main slider to round up the number. Here's a breakdown to the expressions, etc.
Text Layer: Source
n = 0+effect("Slider Control")("Slider");
s = "" + n;
str
The code above links to the new slider, which is applied to the text layer:
n = comp("LINK TO MAIN SLIDER");
d = 1;
Math.round(n*d)/d;
I am pretty sure there's a simpler way to get this expression but I am happy that I have solved it myself. :^D
Thank you!
Addz
Adam Jozef Zygadlo
07708 124 915
Kalle Kannisto
on Sep 7, 2016 at 1:07:05 pm
Perfectly valid solution. Yes, you could do it without the intermediate slider, but hey, where's the fun in that?
Kalleheikki Kannisto
Senior Graphic Designer
Dan Ebberts
on Sep 7, 2016 at 1:09:04 pm
Try this:
Math.round(n).toString().replace(/\B(?=(\d{3})+(?!\d))/g, ",");
Dan
Adam Zygadlo
on Sep 7, 2016 at 2:25:16 pm
Thank you Dan. The expression looks so much cleaner. Defo will save this line of code for future projects but I'll stick to my version for now. ;^)
Thanks again to everyone!
Cheer,
Addz
Adam Jozef Zygadlo
07708 124 915
