After Effects Scripting/ How to parent two values of the layers placed in different compositions
COW Forums : Adobe After Effects Expressions
Karen Harutyunyan
on Sep 5, 2016 at 3:44:22 pm
Hi there.
Need help in scripting !!! I want to parent current values (for example "position") of two layers (for example Null objects) which are placed in two different Comps.
Thanks in advance!!!
Dan Ebberts
Re: After Effects Scripting/ How to parent two values of the layers placed in different compositions
on Sep 5, 2016 at 3:54:27 pm
Parenting is limited to layers in the same comp, but you could connect whichever properties you want with expressions:
comp("other comp").layer("other null").transform.position
Dan
Karen Harutyunyan
on Sep 5, 2016 at 5:32:01 pm
Thanks for your respond.
Is it possible to integrate expression into script ? As I understand this expression must be written to the layer(in my example Null) property(in my case it is position). But how to integrate it into my script ?
Thanks in advance.
Dan Ebberts
on Sep 5, 2016 at 5:47:27 pm
Like this, I guess:
myLayer.property("Position").expression = 'comp("other comp").layer("other null").transform.position';
Dan
Andrew Orlow
on Sep 6, 2016 at 2:44:12 pm
Really?! It's possible to define expressions this way?
Wow, never knew
Karen Harutyunyan
on Sep 7, 2016 at 6:52:38 am
Yes that was exactly what I wanted. Thank you Dan very much. Everything works in proper way.
