Audio to Keyframe fade out
COW Forums : Adobe After Effects Expressions
James Hepher
on Aug 29, 2016 at 2:13:51 pm
Hi there,
I'm trying to hold and fade out on flashing solid.
It's opacity value is creating using an audio to keyframe object.
Any advice would be grateful.
Many thanks,
J
David Conklin
Re: Audio to Keyframe fade out
on Aug 29, 2016 at 5:23:10 pm
Try something like this:
//This gets the audio from the audio Amplitude layer that 'Convert Audio to Keyframes' made
var aud = thisComp.layer("Audio Amplitude")("Effects")("Both Channels")("Slider");
// This gets the value of the Opacity property BEFORE you applied the expression. Basically returns the value you'd see when
// you click the 'opacity' value box to enter a value. It then divides that by 100 to give you a range 0-1 instead of 0-100.
var offset = value/100;
// Now, we multiply the audio data by our offset.
aud*offset
What this does, is that it allows you to keyframe your opacity from 0-100, and have that compound on top of the data that's being created by the Audio to Keyframes. So, just paste this expression onto opacity, set a keyframe at 100 for when you want the fade out to begin, and a keyframe at 0 when you want the fade to be complete. This works because when your opacity is 100, we divide it by 100 and get a value of 1. The audio data multiplied by 1 is just the audio data. When our opacity is 0, we multiply the audio value by 0 and get 0. When our opacity is 50, we divide that by 100 to get 0.5, and 0.5 times our audio data is half of the value.
I hope that makes sense. Give it a try and let me know if it doesn't work!
David Conklin
mographcode.tumblr.com
James Hepher
on Aug 30, 2016 at 10:31:48 am
It doesn't seem to be doing what I need.
I think I need to create some sort of linear ramp from 100-0.
So when the opacity is 100 it automatically trigger a ramp that fades out for a set duration.
Any ideas?
Cheers,
J
