dropdownlist error in script UI
COW Forums : Adobe After Effects Expressions
Anton Schleitre
on Aug 22, 2016 at 6:00:01 pm
Hi there,
I'm new to scripting and wrote a script that actually does everything I want. The only problem I got is that the dropdownlist of my UI only shows it's contents about 90% of the time. 10% of the time the dropdownlist is just empty. I have tested it with CS4 and the newest CC2015 version. I am clueless since it works most of the time. Maybe someone sees something I don't. Most of the time when the error occurs is when I run the script for the first time. If I run it directly afterwards it works just fine. Any help would be more than appreciated. Best Regards, Anton
This is the code:
(after some checks for user mistakes, function "startScript" is being called)
var maskList = new Array;
maskList[0] = "Like in Project Folder";
maskList[1] = "Randomly";
function startScript (effectName){
var myWin = new Window ("palette", "create Object", undefined);
myWin.orientation = "column";
var groupOne = myWin.add("group", undefined, "GroupOne");
groupOne.orientation = "row";
groupOne.add ("statictext", undefined, "Please select the order of footage");
var orderNumber = groupOne.add ("dropdownlist", undefined, maskList);
orderNumber.selection = 0;
var groupTwo = myWin.add("group", undefined, "GroupTwo");
groupTwo.orientation = "row";
var checkboxOne = groupTwo.add("checkbox", undefined, "adjusted Start point");
checkboxOne.value = true;
var groupThree = myWin.add("group", undefined, "GroupThree");
groupThree.orientation = "row";
groupThree.add ("statictext", undefined, "Apply\""+effectName+"\"");
var PAButton = groupThree.add ("button", undefined, "Go!"); (); ();
PAButton.onClick = function caller (){
//(main script, which works fine)
Dan Ebberts
Re: dropdownlist error in script UI
on Aug 22, 2016 at 6:51:49 pm
I can't get it to fail. I notice that maskList is defined outside the function, which will work as long as some other part of the script isn't messing it up. Other than that, I don't know.
Anton Schleitre
on Aug 22, 2016 at 8:05:27 pm
Thank you for your time investigating this, Dan. It's very much appreciated.
maskList is not touched other than what you saw. It's strange...
Thanks again, Dan!
Best Regards
© 2018 All Rights Reserved
