Synchronized wiggle expressions with known values
COW Forums : Adobe After Effects Expressions
Juuso Voutilainen
on Aug 22, 2016 at 12:51:35 pm
Hey everyody
If someone could help me with a problem I have and a tight deadline, I would appreciate it a lot!
I have two layers that are animated by the wiggle expression. Even though I have the same wiggle amounts in both layers, they move in different times. How it would be possible, that the position is transformed at the same time in both of the layers? And on top of that, is it possible to drive the wiggle expression so that it progresses from certain values, like for example from 5 to 10 and from there to 20 and then back to 10 and to 5, in a linear manner. My knowledge in expressions is extremely basic and I if someone with more advanced knowledge would help me out, that would be awesome. Thank you!
Best regards
Juuso
Neil Hammers
Re: Synchronized wiggle expressions with known values
on Aug 25, 2016 at 12:48:08 pm
you can create a custom Expression Slider with a wiggle, like
wiggle(5,10)
and link both layers' positions to this Slider with code:
value+effect("Slider Control")("Slider")
Nh
