How to change layer rotation accordingly to his direction
COW Forums : Adobe After Effects Expressions
Alex Carou
on Aug 18, 2016 at 7:43:18 pm
Hi creativecow community,
I can't solve this by myselfe and I would like to ask some help for this problem.
Imagine a tall tree wich its enchor point is at its foot. I want to move it from left to right and rotate it by his speed.
The greater its speed grow, the greater it will rotate. So I put this expression in ...
Rotation : {-position.speed/9 -15};
But however the direction it takes, It will rotates only in one direction. I search everywhere to find an expression that will "reverse" the rotation by his direction movement.
I try to learn to build my own expressions, in little bits.
Thank you in advance to help me out.
Dan Ebberts
Re: How to change layer rotation accordingly to his direction
on Aug 19, 2016 at 12:09:55 am
Try replacing:
position.speed
with:
position.velocity[0]
Dan
Alex Carou
on Aug 19, 2016 at 1:21:19 am
It kind work when I drag it in X positions but when I preview, It stuck in an same angle until it jump to the next keyframe.
Dan Ebberts
on Aug 19, 2016 at 2:28:03 am
Are you using linear keyframes? If so, the speed won't change--try changing the keyframes to Easy Ease.
Dan
Alex Carou
on Aug 19, 2016 at 2:51:03 pm
It work! Now I need to apply a "spring" effect on the rotation. So, when the "speed.position == 0 ", it should decay his amplitude from the rotation value one frame before it stop.
