Collect files with Expressions
COW Forums : Adobe After Effects Expressions
Nicolas J RUSSO
on Aug 9, 2016 at 6:38:29 pm
Hi, I just ended a project that was a cumulative of templates, so it ended up being a really messy project since the templates were use partially. I did a collect, reduce file, try the script SAVE COMP AS PROJECT... all of them have the same problem: they do not collect the files that are used in the project´s scripts but only the ones that were used as part of the composition. So when I open the new "reduced" project, a lot of things are offline and AE shows me hundreds of error windows like the one I attached
Is there a way to get around this?
