script to sequence the numerous layers quickyl
COW Forums : Adobe After Effects Expressions
jay sahoo
on Jul 11, 2016 at 4:04:08 pm
Hello All - I have a comp where I have several layers stacked up one by one. As a bare minimum to start with I want
all the layers to line up one by one so that I don't need to manually drag one layer's in point to the end of previous layer.
It will take lot of time if I have to manually adjust all these layers (there are more than 60 of them).
Is there anyway i can do it automatically through any script or something similar. Is there any help someone can provide?
Much appreciated. Thanks!
Dan Ebberts
Re: script to sequence the numerous layers quickyl
on Jul 11, 2016 at 4:11:00 pm
How about AE's Sequence Layers menu option?
Animation > Keyframe Assistant > Sequence Layers...
Dan
jay sahoo
on Jul 11, 2016 at 5:00:02 pm
Thank you so much Dan. Much appreciated.
jay sahoo
on Jul 11, 2016 at 5:06:08 pm
Hello Dan - on the similar context if I want to rename a number of layers (for ex: I need to rename all the layers where the name starts with "Metallic" to "Regent") how do I do that? Is there any easy way to do or I need to go manually change one by one? Please advise.
Dan Ebberts
on Jul 11, 2016 at 5:21:11 pm
I think a little script like this should work:
str1 = "Metallic";
str2 = "Regent";
var comp = app.project.activeItem;
for (var i = 1; i <= comp.numLayers; i++){
if (comp.layer(i).name.substr(0,str1.length) == str1)
comp.layer(i).name = str2 + comp.layer(i).name.substr(str1.length);
Dan
jay sahoo
on Jul 11, 2016 at 8:30:20 pm
Thanks again Dan!! works great!! Much appreciated.
