Why is this expression not working?
COW Forums : Adobe After Effects Expressions
David Cabestany
on Jul 5, 2016 at 10:07:00 pm
I'm using the expression below.
It works ok, but as you can see I have no need for variable "y", however if I remove it the expression breaks and gives an error stating expression result must be of dimension 2, not 1.
I know the answer is simple: Do not remove y, but I'm a bit OCD and I like to have clean code.
Any ideas?
Best,
D.
topVal=100
fadeDur = 1;
if (time &lt; (inPoint+outPoint)/2)
x=ease(time,inPoint,inPoint+fadeDur,0,topVal)
else
x=ease(time,outPoint-fadeDur,outPoint,topVal,0)
y=100;
[x,x];
Dan Ebberts
Re: Why is this expression not working?
on Jul 5, 2016 at 10:15:13 pm
I think you just need to add a semicolon to the line above the one you're taking out.
Dan
David Cabestany
on Jul 5, 2016 at 10:29:12 pm
Yep, that was it.
Thanks Dan.
