Triggering RAM Preview via script
COW Forums : Adobe After Effects Expressions
Irene Nelson
on Jun 10, 2016 at 10:38:22 pm
Does After Effects allow a script to trigger the RAM preview? I was hoping to make one that would turn off the visibility of a certain type of layer (probably determined by label type), then trigger a RAM preview... and ideally revert the visibility change once the preview is stopped.
The visibility bit is not a problem, but I haven't been able to find any documentation for how I would call the preview, and am guessing that means it might not be possible... or just way more complicated than it's worth. Any thoughts?
Xavier Gomez
Re: Triggering RAM Preview via script
on Jun 11, 2016 at 5:52:29 am
From beginning to end of the workbar area:
myComp.ramPreviewTest(checkerboards, zoom, exposure);
(returns a string).
To play the ram preview with the same settings as the ones in the current viewer:
var i = app.activeViewer.activeViewIndex;
var options = app.activeViewer.views[i].options;
then use view.checkerboards (boolean), view.zoom (number), and view.exposure (number) as arguments.
© 2018 All Rights Reserved
