Beam effect from behind camera?
COW Forums : Adobe After Effects Expressions
Hamid Rohi-Bilverdy
on May 26, 2016 at 8:04:39 pm
Hi
I followed a tutorial where a laser beam writing on a wall. The plugin is BCC laserbeam.it has an option to use The comp light. Then when moving the light futher behind the camera it gives this nice sence of depth.
How can i accomplish this with the native beam effect??
I have tried to link the end point to light and camera parameters but no luck here. The beam is not a 3d effec. But i figure there must be a way to pull this of
Hamid Rohi-Bilverdy
Re: Beam effect from behind camera?
on May 27, 2016 at 8:06:02 pm
Anyone??
Dan Ebberts
on May 27, 2016 at 8:13:19 pm
I think the best you could do would be to set the start point of the beam to the light's position projected onto the comp view:
thisComp.layer("Light 1").toComp([0,0,0]);
You'd probably want a large Starting Thickness, maybe tied in some way to the light's z position.
Dan
Hamid Rohi-Bilverdy
on May 28, 2016 at 6:16:20 pm
Thank you very much Sir D.E
Your spot on...
Br HRB
