XML excel spreadsheet - access text in cells.
COW Forums : Adobe After Effects Expressions
Fabio Apelbaum
on May 23, 2016 at 4:29:02 pm
Hi guys!
Im trying to use an excel spreadsheet (XML) to change text layers In my after effects project, I was looking at the code inside the excel spreadsheet XML I have and this text that I am trying to access seems to be inside namespaces, such as in this sample: Data ss:Type='String'>original text /Data. is there a way to retrieve "original text"?
Please find some of the code I have so far in the image attached, I included the xml inside my code just to test it, later I will write my script to gather the XML info from an XML Excel file.
This is what the XML file looks like:
And this is so far, the code that I was able to put together, it just does not do what I need yet....
Thank you all in advance!!
