What am I doing wrong?
COW Forums : Adobe After Effects Expressions
Will Bugden
on May 21, 2016 at 3:44:18 am
I've applied this expression
frames ++;
if (frames == 2) {
transform.position = [random()*5, random()*5];
frames = 0;
to position under transform and get this error
Error at line 1 in property 'Position' of layer 12
when I remove everything except
the expression will show no errors
frames ++;
if (frames == 2) {
frames = 0;
Dan Ebberts
Re: What am I doing wrong?
on May 21, 2016 at 5:19:44 am
You haven't defined "frames". I'm not sure what you're trying to do, but it looks like maybe you're trying to set a random position and have it not change, which might look like this:
seedRandom(index,true);
random([5,5])
Dan
Will Bugden
on May 21, 2016 at 6:43:23 am
How do I define "frames"?
Dan Ebberts
on May 21, 2016 at 7:37:27 am
You can get the current frame with something like:
curFrame = timeToFrames(time);
What is it that you're trying to do?
I can't tell if you're aware of this (apologies if you are), but nothing that happens in an expression survives from one frame to the next. An expression has no way to reference past variable values or past results. You can re-calculate everything, but it won't just be waiting there.
Dan
