Text Counter Connected to Layers Z-Rotation
COW Forums : Adobe After Effects Expressions
Doug Sand
on May 17, 2016 at 5:12:33 pm
I'm trying to build an analog meter with a digital text readout. Basically, I need the the source text to read out the rotational value of another layer. As you can see in the image, I want it to be able to read 0 when the needle is at 0, 1 when the needle is at 1 and so on and so forth.
All help is much appreciated!
Xavier Gomez
Re: Text Counter Connected to Layers Z-Rotation
on May 17, 2016 at 5:41:46 pm
This might work:
minRot = -75;
maxRot = 75;
minValue = 0;
maxValue = 6;
rot = thisComp.layer("Shape Layer 3").transform.zRotation;
linear(rot, minRot, maxRot, minValue, maxValue);
Xavier
Doug Sand
on May 17, 2016 at 5:46:35 pm
Genius, genius, genius! One last question. What can I add to the code to keep the text to only two decimal points?
-Doug
Xavier Gomez
on May 17, 2016 at 6:46:04 pm
***If you want exactly 2 decimals, you can use:
... // same beginning
x = linear(rot, minRot, maxRot, minValue, maxValue);
x.toFixed(2);
***And if you want at most 2 decimals:
Math.floor(x*100)/100;
Xavier
